I’m using latest Ubuntu, fully up-to-date, with Apache 2.4.17 supporting https2. I’ve also pagespeed.
So when running letsencrypt, I got the following error:
root@ns1:/tmp/letsencrypt# ./letsencrypt-auto --apache
Updating letsencrypt and virtual environment dependencies…
Running with virtualenv: /root/.local/share/letsencrypt/bin/letsencrypt --apache
The apache plugin is not working; there may be problems with your existing configuration.
The error was: PluginError((‘There has been an error in parsing the file (%s): %s’, u’/etc/apache2/mods-enabled/pagespeed.conf’, u’Syntax error’),)
So I guess there is some inconsistency ?
