This morning my certificate for intelligenthost.net expired. The challenge looks like it went through, as it is no in pending. But the order seems to be stuck. My certs are created by the ClusterIssuer and my ingres. I pasted part of my ingress below.
This is from my ingress.yaml
apiVersion: networking.k8s.io/v1
kind: Ingress
metadata:
annotations:
kubernetes.io/ingress.class: nginx
cert-manager.io/cluster-issuer: "letsencrypt"
nginx.org/client-max-body-size: "0"
nginx.ingress.kubernetes.io/proxy-body-size: "0"
\ name: ingress-pacprops
namespace: default
spec:
tls:
- hosts:
Events:
Type Reason Age From Message
Normal Created 7m54s cert-manager-orders Created Challenge resource "tls-intelligenthost-net-dvkrq-2517195546-2985535495" for domain "intelligenthost.net"
v1.10.0
NAME READY STATUS RESTARTS AGE
pod/cert-manager-84bc577876-nm59k 1/1 Running 0 17m
pod/cert-manager-cainjector-99d4695d7-kpwb7 1/1 Running 0 17m
pod/cert-manager-webhook-7bff7c658f-kvwnh 1/1 Running 0 17m
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE
service/cert-manager ClusterIP 10.245.163.80 9402/TCP 25d
service/cert-manager-webhook ClusterIP 10.245.159.49 443/TCP 25d
kubectl ClusterIssuer -o wide
NAME READY STATUS AGE
letsencrypt True The ACME account was registered with the ACME server 30m
letsencrypt-staging True The ACME account was registered with the ACME server 30m
n/a
DigitalOcean
kubectl version
Client Version: version.Info{Major:"1", Minor:"22", GitVersion:"v1.22.0", GitCommit:"c2b5237ccd9c0f1d600d3072634ca66cefdf272f", GitTreeState:"clean", BuildDate:"2021-08-04T18:03:20Z", GoVersion:"go1.16.6", Compiler:"gc", Platform:"linux/amd64"}
Server Version: version.Info{Major:"1", Minor:"22", GitVersion:"v1.22.13", GitCommit:"a43c0904d0de10f92aa3956c74489c45e6453d6e", GitTreeState:"clean", BuildDate:"2022-08-17T18:23:45Z", GoVersion:"go1.16.15", Compiler:"gc", Platform:"linux/amd64"}
