OCSP stapling phase out practicalities
With the recent announcement of the retirement of OCSP stapling I wondered what is the correct way to phasing out the feature from a server.
I currently run an nginx with
ssl_stapling on; ssl_stapling_verify on;
and just disabling this leads to problems due to the stapling flag in the certificate being set.
Is it enough to swap the must_staple flag in /etc/letsencrypt/renewal/domain.conf, so the next extension of the certificate will not bear the OCSP stapling extension?
Let's Encrypt has not yet decided to e.g. continue supporting OCSP for certificates with the must_staple feature extension enabled or e.g. to either refuse or simply not add the must_staple flag when renewing.
My advice would be to follow What will happen to Must-Staple and the API Announcements - Let's Encrypt Community Support category while Let's Encrypt makes up their mind on what to do with regard to must_staple.
I think you will need to remove ssl_stapling_verify on.
I also think that would be necessary too.
But which ACME Client are you using,
and check its document as well.
And definitely follow Osiris’ advice above.
