Failed authorization procedure. forumserver.twoplustwo.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Timeout
My web server is (include version): Apache/2.4.6
Red Hat Enterprise Linux Server release 7.4 (Maipo)
rackspace
The server I ran this on is one of three behind a brocade load balancer.
I am unsure how to use an alternative client to obtain a certificate. Any help would be appreciated.
Generally --apache can't work at all behind a load balancer, while --webroot can potentially work if you can closely customize the load balancer's behavior (and if it's listening on port 80).
Do you have a way to update the DNS records in the DNS zone file for this domain via an API of some kind? That might be an easier strategy (using the DNS-01 authorization method instead).
Some tools (including Certbot and also acme.sh to a greater extent) let you do this via a DNS provider API rather than manually, which can make the process nicer when you have to renew the certificate (because you have to re-validate). So you might want to keep automation in mind too if you didn’t use a process initially that can be automated.
