Not sure what im doing wrong
My domain is: rollinghillsrabbitry.com
I ran this command: sudo certbot --nginx
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated) (Enter ‘c’ to cancel): www.rollinghillsrabbitry.com, rollinghillsrabbitry.com
requested (ref: /etc/letsencrypt/renewal/rollinghillsrabbitry.com.conf)
It contains these names: rollinghillsrabbitry.com
You requested these names for the new certificate: www.rollinghillsrabbitry.com,
certificate?
(E)xpand/©ancel: e
http-01 challenge for www.rollinghillsrabbitry.com
Waiting for verification…
Deploying Certificate to VirtualHost /etc/nginx/sites-enabled/www
nginx: [emerg] could not build server_names_hash, you should increase server_names_hash_bucket_size: 32
Rolling back to previous server configuration…
nginx restart failed:
b’’
b’’
  • We were unable to install your certificate, however, we
    successfully restored your server to its prior configuration.
    /etc/letsencrypt/live/rollinghillsrabbitry.com/fullchain.pem
    /etc/letsencrypt/live/rollinghillsrabbitry.com/privkey.pem
    Your cert will expire on 2020-12-08. To obtain a new or tweaked
    with the “certonly” option. To non-interactively renew all of
    your certificates, run “certbot renew”
My web server is (include version): nginx/1.18.0 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 20.04.1 LTS
My hosting provider, if applicable, is: myself
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 1.8.0
I fail to see the reason for your topic…
Is there a problem?
What is the problem?
I got it fixed thank you.
