What is telling your site is not secure? And, what exactly is the message? Can you upload screen shot or something?
I see your domain using a cert issued today. The same as whynopadlock shows and also SSL Labs Server test (here)
Your domain is using Cloudflare's CDN service so it is unlikely to get a failed cert with that since it manages the certs between its edge and clients (like browsers)
You're using CloudFlare CDN.
So, the Internet only sees the CDN [which is secured with a valid wildcard certificate].
If you are connecting to your server directly and that shows "not secure", then you need to show us the certificate it uses [and you may need to update that certificate (like missing "www") OR restart the web service, if that certificate has already been renewed]
