Not able to renew certificate
My domain is: koha.mes.ac.in
library.mes.ac.in
opac.mes.ac.in
Processing /etc/letsencrypt/renewal/koha.mes.ac.in.conf
Renewing an existing certificate for koha.mes.ac.in and 2 more domains
Domain: library.mes.ac.in
Type: dns
Detail: no valid A records found for library.mes.ac.in; no valid AAAA records found for library.mes.ac.in
Failed to renew certificate koha.mes.ac.in with error: Some challenges have failed.
/etc/letsencrypt/live/koha.mes.ac.in/fullchain.pem (failure)
The operating system my web server runs on is (include version): UBUNTU 20
I can login to a root shell on my machine (yes or no, or I don't know): YES
Hi @nayema, and welcome to the LE community forum :slight_smile:
If you are using HTTP authentication, you will need to use only IPs that can be routed over the Internet:
Address: 192.168.0.6
Thank you for your quick reply. Let me know about other two domains since they are routed over internet
  1. koha.mes.ac.in
    2.opac.mes.ac.in
Public DNS shows:
Address: 203.115.126.36
Those other two hostnames weren't giving you trouble when renewing, only library.mes.ac.in.
ok. Thank you.
