ice00
November 19, 2023, 5:14pm
1
My domain is: boinc-multi-pool.info
certbot renew --dry-run --webroot -w /var/www/html --cert-name boinc.multi-pool.info -v
Processing /etc/letsencrypt/renewal/boinc.multi-pool.info.conf
Certificate is due for renewal, auto-renewing...
Simulating renewal of an existing certificate for boinc.multi-pool.info
http-01 challenge for boinc.multi-pool.info
Using the webroot path /var/www/html for all unmatched domains.
Challenge failed for domain boinc.multi-pool.info
Domain: boinc.multi-pool.info
Detail: 78.26.93.125: Invalid response from http://boinc.multi-pool.info/.well-known/acme-challenge/OGZjGBnbXRYEPADWO7WcJW_vU820Y_cQS4560z9dUt4: 404
Failed to renew certificate boinc.multi-pool.info with error: Some challenges have failed.
All simulated renewals failed. The following certificates could not be renewed:
/etc/letsencrypt/live/boinc.multi-pool.info/fullchain.pem (failure)
apache 2.4.52-1ubuntu4.6
Ubuntu with kernel 5.15.0-88-generic
godaddy
no
certbot 1.21.0
9peppe
November 19, 2023, 8:04pm
2
ice00:
/var/www/html
Check your apache config, see if that's the actual webroot for boinc.multi-pool.info
Using the online tool Let's Debug yields these results https://letsdebug.net/boinc-multi-pool.info/1682421
NoRecords
FATAL
No valid A or AAAA records could be ultimately resolved for boinc-multi-pool.info. This means that Let's Encrypt would not be able to connect to your domain to perform HTTP validation, since it would not know where to connect to.
No A or AAAA records found.
And using the online tool Unbound DNS checker yields these results for A records https://unboundtest.com/m/A/boinc-multi-pool.info/EL7FIBPR
Query results for A boinc-multi-pool.info
Response:
;; opcode: QUERY, status: NXDOMAIN, id: 1194
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 8, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version 0; flags: do; udp: 512
;; QUESTION SECTION:
;boinc-multi-pool.info. IN A
;; AUTHORITY SECTION:
info. 0 IN SOA a0.info.afilias-nst.info. hostmaster.donuts.email. 1700425289 7200 900 1209600 3600
info. 0 IN RRSIG SOA 8 1 3600 20231210202639 20231119192639 42411 info. PYl9jw0Y+4dGJceAN3V+v2pAi9jzLSBnbrfMibRNZSNXa9DPyEuVj76+FfL8dP+sItwHqQAF/LCxBpFpfIrGoIQ++bboyv2i29nODDSS3M1tRFrsvCz+V0N+9ePtfirKpFr32HK4wkuRwZ/TP65DFaHCLAJMggoJp0rYG5eA4mM=
526vog7afjquqdgqpn9o8lm7bn5gape8.info. 0 IN NSEC3 1 1 100 332539EE7F95C32A 52773GNHC4FIMJ8HCRSHIGOIHQ1EGS2G NS SOA RRSIG DNSKEY NSEC3PARAM
526vog7afjquqdgqpn9o8lm7bn5gape8.info. 0 IN RRSIG NSEC3 8 2 3600 20231210202639 20231119192639 42411 info. M+Et25NEzB0ykVRiJuE5jh+aRTTgn1xHKT25JBFyQR65/ZVtKCHuufm4qQXbTpMN6s4VaH8YyGOgSUOHroN/bkvLAOemIAXU0f1UEL6ofLii8ssewqLviP4sHSuXQ+VWN1QYzRlt0fmQRhSTvFDjP/IpmJ6LxXn+M2PTUtXgOa8=
v9hlencfflkstdbqlpr5tvavckk7kmvd.info. 0 IN NSEC3 1 1 100 332539EE7F95C32A V9HU8DAPN2PT6PT9TR5V18ETAR3GIT9U NS DS RRSIG
v9hlencfflkstdbqlpr5tvavckk7kmvd.info. 0 IN RRSIG NSEC3 8 2 3600 20231210031256 20231119021256 42411 info. LzOGM+XgqkOawLo/0t2xhvkBFAfqWB0ghRqrRMY0RLHojyMazAnk71Lxp8ZoN+adm3dwuTNQAcy7OFY7DzqhuUCMxzQdk9vhXpyjH1Y8iMzB/wiAL1n/js+SQNDB7NGPh6Kz9slQCSwDhJMWWVqXXUQ42iotGGLVYuqkNd4DwjE=
ca7mupnamuqfescv3ontos769t2s97vr.info. 0 IN NSEC3 1 1 100 332539EE7F95C32A CA7Q1NHMJ85VOSBKA84NVE8BLJQJ4HCE NS DS RRSIG
ca7mupnamuqfescv3ontos769t2s97vr.info. 0 IN RRSIG NSEC3 8 2 3600 20231210031256 20231119021256 42411 info. SNtjFQRqUIK8j8Jvs5zNXb5MJp3j4wLJHbiYU5dTU9S3daoBipqRbPN3m3AUfIFk6AeOqCY00sJGH57qzQmITCOncmEnydFGad8mj7oCaCZojUVSx2oaLoDW9PrrGfYo3Xn77UbEMBAVGt4IxtLPcbmLecqiNc9wkOpXw1+a2ko=
----- Unbound logs -----
Nov 19 20:34:56 unbound[600358:0] notice: init module 0: validator
Nov 19 20:34:56 unbound[600358:0] notice: init module 1: iterator
Nov 19 20:34:56 unbound[600358:0] info: start of service (unbound 1.16.3).
Nov 19 20:34:57 unbound[600358:0] query: 127.0.0.1 boinc-multi-pool.info. A IN
Nov 19 20:34:57 unbound[600358:0] info: resolving boinc-multi-pool.info. A IN
And using the online tool Unbound DNS checker yields these results for AAAA records https://unboundtest.com/m/AAAA/boinc-multi-pool.info/35NONSML
Query results for AAAA boinc-multi-pool.info
Response:
;; opcode: QUERY, status: NXDOMAIN, id: 49052
;boinc-multi-pool.info. IN AAAA
info. 0 IN SOA a0.info.afilias-nst.info. hostmaster.donuts.email. 1700425922 7200 900 1209600 3600
info. 0 IN RRSIG SOA 8 1 3600 20231210203715 20231119193715 42411 info. GOGIZRj8F1J+GJDyK+Nx3UIdJdGfMedf4ZM9f2AWEF3YdAS1Z2XXrpDL9vxHmyUK0MptzJx1xUdyu5FTz2IGqu/clnOWSj04lia6KPdn7ivmTUHxT+iTtzqtauowEPEK3jfhqy7hrhWOwR32UmpnDP0fICR2vI1AFqIFTk3Lim8=
526vog7afjquqdgqpn9o8lm7bn5gape8.info. 0 IN RRSIG NSEC3 8 2 3600 20231210203715 20231119193715 42411 info. H2x4TOSsKlzgapNNNBVwOSmpAMps2WyeZJAw9EKhqkgsOYUsHpO079BvDSpYyErUy1BVvn+fdK+lr0qR7c2jiKeQQWqWgdZjLF0cI2MiU4tKB1vLCWeAEA+yuOYg4Y6b55LKuhkOjpUYXa1FD5yfBACPfAi3wv40kamL5l+30mc=
Nov 19 20:37:44 unbound[600362:0] notice: init module 0: validator
Nov 19 20:37:44 unbound[600362:0] notice: init module 1: iterator
Nov 19 20:37:44 unbound[600362:0] info: start of service (unbound 1.16.3).
Nov 19 20:37:45 unbound[600362:0] query: 127.0.0.1 boinc-multi-pool.info. AAAA IN
Nov 19 20:37:45 unbound[600362:0] info: resolving boinc-multi-pool.info. AAAA IN
rg305
November 20, 2023, 3:04am
4
Hi @ice00 , and welcome to the LE community forum
As mentioned:
That is most likely the case.
As you are using Apache I would also check that there are no name:port overlaps, with:
sudo apachectl -t -D DUMP_VHOSTS
ice00
November 20, 2023, 5:26pm
5
VirtualHost configuration:
78.26.93.125:80 boinc.multi-pool.info (/etc/apache2/sites-enabled/latinsquares.httpd.conf:1)
*:80 127.0.0.1 (/etc/apache2/sites-enabled/000-default.conf:2)
*:443 boinc.multi-pool.info (/etc/apache2/sites-enabled/default-ssl.conf:2)
Just to look correctly, for webroot it means the DocumentRoot directive of apache?
ice00
November 20, 2023, 5:31pm
6
The domain multi-pool.info is defined with those DNS entries in Godaddy:
A @ 78.26.93.123 600sec
A boinc 78.26.9.125 1h
A boinc-status 78.26.93.124 1h
Yes; now it looks better.
IPv4 A Record
https://unboundtest.com/m/A/multi-pool.info/IHY33XYX
Query results for A multi-pool.info
Response:
;; opcode: QUERY, status: NOERROR, id: 39220
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
;multi-pool.info. IN A
;; ANSWER SECTION:
multi-pool.info. 0 IN A 78.26.93.123
Nov 20 17:37:32 unbound[609426:0] notice: init module 0: validator
Nov 20 17:37:32 unbound[609426:0] notice: init module 1: iterator
Currently I see https://letsdebug.net/multi-pool.info/1683573
ANotWorking
ERROR
multi-pool.info has an A (IPv4) record (78.26.93.123) but a request to this address over port 80 did not succeed. Your web server must have at least one working IPv4 or IPv6 address.
Get "http://multi-pool.info/.well-known/acme-challenge/letsdebug-test": dial tcp 78.26.93.123:80: connect: no route to host
Trace:
@0ms: Making a request to http://multi-pool.info/.well-known/acme-challenge/letsdebug-test (using initial IP 78.26.93.123)
@0ms: Dialing 78.26.93.123
@3106ms: Experienced error: dial tcp 78.26.93.123:80: connect: no route to host
IssueFromLetsEncrypt
ERROR
A test authorization for multi-pool.info to the Let's Encrypt staging service has revealed issues that may prevent any certificate for this domain being issued.
78.26.93.123: Fetching http://multi-pool.info/.well-known/acme-challenge/ORs5c6Ec1ctvUtzem3i2eR-EWoWtSXIKAViv84JMZHw: Error getting validation data
Using nmap I see your Ports 80 & 443 are filtered ;
Port 80 must be accessible for the HTTP-01 challenge
Best Practice - Keep Port 80 Open
$ nmap -Pn -p80,443 multi-pool.info
Starting Nmap 7.80 ( https://nmap.org ) at 2023-11-20 17:40 UTC
Nmap scan report for multi-pool.info (78.26.93.123)
Host is up.
rDNS record for 78.26.93.123: host-7826-93-123.wifi.asdasd.it
PORT STATE SERVICE
80/tcp filtered http
443/tcp filtered https
Nmap done: 1 IP address (1 host up) scanned in 3.74 seconds
Here is an online Open Port Check Tool - Test Port Forwarding on Your Router tool.
ice00
November 20, 2023, 5:55pm
8
just to know, the server at 78.26.93.123 is now stopped, so access to multi-pool.info (like www.multi-pool.info) will not get browser answers.
If this is a problem for boinc.multi-pool.info certificate, I can make the DNS to point to one of the others two working servers.
ice00
November 20, 2023, 6:54pm
10
ServerName boinc.multi-pool.info
<VirtualHost *:80>
DocumentRoot /var/www/html
</VirtualHost>
rg305
November 20, 2023, 7:05pm
11
The ServerName directive is outside of the VirtualHost definition.
That said, there might be another system handling HTTP or another vhost.
Where does this redirection happen?:
curl -Ii boinc.multi-pool.info
HTTP/1.1 302 Found
Date: Mon, 20 Nov 2023 19:01:51 GMT
Server: Apache/2.4.52 (Ubuntu)
ice00
November 20, 2023, 7:11pm
12
<VirtualHost boinc.multi-pool.info:80>
ServerAlias www.boinc.multi-pool.info
ServerAdmin ice00@libero.it
DocumentRoot /home/boinc/projects/latinsquares/html
Include sites-available/boinc.inc
</VirtualHost>
ice00
November 20, 2023, 7:13pm
13
<IfModule mod_ssl.c>
<VirtualHost _default_:443>
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/boinc.multi-pool.info/cert.pem
SSLCertificateKeyFile /etc/letsencrypt/live/boinc.multi-pool.info/privkey.pem
SSLCertificateChainFile /etc/letsencrypt/live/boinc.multi-pool.info/chain.pem
<FilesMatch "\.(cgi|shtml|phtml|php)$">
SSLOptions +StdEnvVars
</FilesMatch>
<Directory /usr/lib/cgi-bin>
</Directory>
</VirtualHost>
</IfModule>
ice00
November 20, 2023, 7:17pm
14
/etc/apache2/sites-available/boinc.inc
RedirectMatch ^/$ /latinsquares/
Alias /latinsquares/download /home/boinc/projects/latinsquares/download
Alias /latinsquares/stats /home/boinc/projects/latinsquares/html/stats
Alias /latinsquares/user_profile /home/boinc/projects/latinsquares/html/user_profile
Alias /latinsquares /home/boinc/projects/latinsquares/html/user
Alias /latinsquares_ops /home/boinc/projects/latinsquares/html/ops
ScriptAlias /latinsquares_cgi /home/boinc/projects/latinsquares/cgi-bin
then there is all the Directory directived of all alises defined before
rg305
November 20, 2023, 7:20pm
15
The same names are being served in two vhost config files.
That's a "name:port " ovelap - as I suspected.
rg305
November 20, 2023, 7:22pm
16
Try this again [and show all the output]:
ice00
November 20, 2023, 7:25pm
17
MikeMcQ
November 20, 2023, 7:56pm
18
Agreed. Further, they are mixing IP and Name based Virtual hosts. This will likely cause them problems.
In the first one below the name boinc.multi-poo.info in the VirtualHost statement is just converted to an IP by Apache.
ice00:
<VirtualHost *:80>
ice00
November 26, 2023, 3:21pm
19
hi,
after modification as suggested, it goes:
Congratulations, all simulated renewals succeeded:
/etc/letsencrypt/live/boinc.multi-pool.info/fullchain.pem (success)
