Not able to generate certificate with --nginx option
My domain is: b9cd6905.ngrok.io
I ran this command: sudo certbot --nginx
http-01 challenge for b9cd6905.ngrok.io
Using default address 80 for authentication.
Challenge failed for domain b9cd6905.ngrok.io
My web server is (include version): nginx version: nginx/1.6.3
The operating system my web server runs on is (include version): macos mojave 10.14.3
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.33.1
Additional Details
host b9cd6905.ngrok.io
b9cd6905.ngrok.io has address 3.19.114.185
b9cd6905.ngrok.io has IPv6 address 2600:1f16:d83:1200:5f48:aa8e:f610:571d
Note:
I am able to create certificate manually and webroot, but when i am trying with nginx its giving above error
Hi @ketansomani
simple answer: Then use the webroot - option. If --nginx doesn't work, but webroot does, your configuration is buggy.
certbot run -a webroot -i nginx -w yourwebroot -d b9cd6905.ngrok.io
