No valid IP address found
Ok so I ran the same command you did against a local copy of my software as well as my production name servers and everything works as expected.
Maybe there's a problem somewhere in the middle?
dig @ns1.callahtech.com +trace +bufsize=512 mail.callahtech.com
; <<>> DiG 9.16.1-Ubuntu <<>> @ns1.callahtech.com +trace +bufsize mail.callahtech.com
; (1 server found)
;; global options: +cmd
.                       300     IN      NS      ns1.callahtech.com.
.                       300     IN      NS      ns2.callahtech.com.
;; Received 79 bytes from 98.213.184.202#53(ns1.callahtech.com) in 25 ms
mail.callahtech.com.    300     IN      CNAME   safari.mxrouting.net.
;; Received 90 bytes from 98.213.184.202#53(ns1.callahtech.com) in 21 ms
dig @ns2.callahtech.com +trace +bufsize=512 mail.callahtech.com
; <<>> DiG 9.16.1-Ubuntu <<>> @ns2.callahtech.com +trace +bufsize mail.callahtech.com
; (1 server found)
;; Received 79 bytes from 35.231.196.113#53(ns2.callahtech.com) in 46 ms
;; Received 90 bytes from 98.213.184.202#53(ns1.callahtech.com) in 26 ms
dig @192.168.73.1 +trace +bufsize=512 mail.callahtech.com
; <<>> DiG 9.16.1-Ubuntu <<>> @192.168.73.1 +trace +bufsize mail.callahtech.com
; (1 server found)
;; Received 48 bytes from 192.168.73.1#53(192.168.73.1) in 2 ms
;; Received 90 bytes from 98.213.184.202#53(ns1.callahtech.com) in 22 ms
I also enabled TCP connections on both name servers / adjusted firewall rules
dig +tcp +trace +bufsize=512 mail.callahtech.com
; <<>> DiG 9.16.1-Ubuntu <<>> +tcp +trace +bufsize mail.callahtech.com
.                       42032   IN      NS      a.root-servers.net.
.                       42032   IN      NS      k.root-servers.net.
.                       42032   IN      NS      c.root-servers.net.
.                       42032   IN      NS      e.root-servers.net.
.                       42032   IN      NS      f.root-servers.net.
.                       42032   IN      NS      j.root-servers.net.
.                       42032   IN      NS      g.root-servers.net.
.                       42032   IN      NS      d.root-servers.net.
.                       42032   IN      NS      h.root-servers.net.
.                       42032   IN      NS      m.root-servers.net.
.                       42032   IN      NS      b.root-servers.net.
.                       42032   IN      NS      i.root-servers.net.
.                       42032   IN      NS      l.root-servers.net.
.                       42032   IN      RRSIG   NS 8 0 518400 20210428050000 20210415040000 14631 . VAN9EL8cU10Xk+mcU4q/t0W3EZ4iS/YJ/gmAVuIhTCmuQQcFEN0++99t T1oVdJWRtSQBMoaLbliwEOtEb5tJ5aEsYJB1gzVWTRQrP9IKK2CGoOYL u8sMSoJFz1VEbwG+HGtkK9QFW4PI7TucPkHSgTIJCJO3q8UqIvP4Nmd6 mB+jKgrz11vKDzQgSZBHFOMYgrq8MiG8R+dU/lc5gVIpyUDYBiZXvFhB v9Fl7wwiCHf0oe7kp8Zeo5VEzgEgepXuGfiHx1dA32FbMiWXNMhxsmlJ MaGrQ754BE/0hkNSRA7afsuKTWvRi3qdSePJf4HSAVmVQp/t703xjSui /twc+A==
;; Received 1111 bytes from 10.1.2.4#53(10.1.2.4) in 26 ms
;; Connection to 2001:500:1::53#53(2001:500:1::53) for mail.callahtech.com failed: connection refused.
;; Connection to 2001:500:200::b#53(2001:500:200::b) for mail.callahtech.com failed: connection refused.
com.                    172800  IN      NS      c.gtld-servers.net.
com.                    172800  IN      NS      j.gtld-servers.net.
com.                    172800  IN      NS      k.gtld-servers.net.
com.                    172800  IN      NS      b.gtld-servers.net.
com.                    172800  IN      NS      d.gtld-servers.net.
com.                    172800  IN      NS      f.gtld-servers.net.
com.                    172800  IN      NS      l.gtld-servers.net.
com.                    172800  IN      NS      e.gtld-servers.net.
com.                    172800  IN      NS      h.gtld-servers.net.
com.                    172800  IN      NS      i.gtld-servers.net.
com.                    172800  IN      NS      m.gtld-servers.net.
com.                    172800  IN      NS      g.gtld-servers.net.
com.                    172800  IN      NS      a.gtld-servers.net.
com.                    86400   IN      DS      30909 8 2 E2D3C916F6DEEAC73294E8268FB5885044A833FC5459588F4A9184CF C41A5766
com.                    86400   IN      RRSIG   DS 8 1 86400 20210428210000 20210415200000 14631 . Nq8NGgqWe3KvGbJpbOhwU5m2EPe2tZ3l4KLQ5Po2HZeTX/UMPihdRFmj MzHJlblQ5Nj1LyLT0y3R4tBP3C2yLUjZofetXT3Rk4R1qtanBMvIevi1 SEAi6EiEdXM7V4+GsVr3pmXuSCtrRJxd31KleTYSg2o0GjTs2y2ZEKIA h5d3n86sc1e9WLvsw7yGNRY5LRpce9p4vrzI5t51QOq8N0kqMn5D224M jFEu9Y88QWNOzkbHGpd7W8184QMjNSptLU2yEe93zMelvdmsj0e5UYwj ykE6mJWsXCnbZtqiw1iO03xWiaCMw0bb8AkOJN9dUZjXEgwPhRKeyDs/ Lg7eDw==
;; Received 1210 bytes from 192.36.148.17#53(i.root-servers.net) in 65 ms
;; Connection to 2001:500:d937::30#53(2001:500:d937::30) for mail.callahtech.com failed: connection refused.
callahtech.com.         172800  IN      NS      ns1.callahtech.com.
callahtech.com.         172800  IN      NS      ns2.callahtech.com.
CK0POJMG874LJREF7EFN8430QVIT8BSM.com. 86400 IN NSEC3 1 1 0 - CK0Q1GIN43N1ARRC9OSM6QPQR81H5M9A NS SOA RRSIG DNSKEY NSEC3PARAM
CK0POJMG874LJREF7EFN8430QVIT8BSM.com. 86400 IN RRSIG NSEC3 8 2 86400 20210422042410 20210415031410 58540 com. fePohSpUOL9K9eCljlIgjwl8TiSbS1ahDo0B1FI9aIIZA3u1AuzKQgzK yRxC56l4SXq5oLvuUe8Xti4/G8ARewoTTNtgNN0KWIj7PKCNdLDSQYtu nF3HoZZLtoKomKgq6YXbdwt9+6Qern+as2SAI2pWvPPjsGVx0400tCNY C1YgPGOuMomEm/Fg/aWwW6uv/a+k7SJPSKIvJ0CLHiCmuw==
H65L7M3MIGIV8R2KQCESNJ40P899F280.com. 86400 IN NSEC3 1 1 0 - H65L7OIBUMRA7PJ9OMCNLLC3US4O2KDT NS DS RRSIG
H65L7M3MIGIV8R2KQCESNJ40P899F280.com. 86400 IN RRSIG NSEC3 8 2 86400 20210420042850 20210413031850 58540 com. xiE7huTczKb9V2kdess7uuV2zH3heV/nhU9EEVl3KO5LeWPO5+o+WoRV 8fsi8MGx/Jm/2XH4FuhNXWVp6ue2bAgLJpH4LNhHqZP1oN71kgVmBu7d B5B3dVEH6Hq+EEFyG7OUoCFyAWRQq2+Bg/v+Y/nZinv9SrgKY2OYgJKS Lsuj8Crdt/3H4GysjDh7Mh2u9i09/swd0LUfSNQHaCH8GQ==
;; Received 665 bytes from 192.54.112.30#53(h.gtld-servers.net) in 54 ms
;; expected opt record in response
;; Received 90 bytes from 35.231.196.113#53(ns2.callahtech.com) in 78 ms
It still doesn't work: https://unboundtest.com/m/A/mail.callahtech.com/QI3D22U6
I can confirm that now that TCP is working for it, my dig traces are working too.
Now I'm quite stumped as well.
It's always the stupidest thing isn't it...
nslookup MAil.CallahTEch.coM 10.1.2.7
Server:  ns1.callahtech.com
Address:  10.1.2.7
*** No internal type for both IPv4 and IPv6 Addresses (A+AAAA) records available for MAil.CallahTEch.coM
Anyways... Thanks for the help guys.
https://unboundtest.com/m/A/mail.callahtech.com/WVVSAC2V
So glad you figured it out! I'll have to remember about testing DNS case randomization next time I see a weird DNS problem.
