No valid A records found
No, I said:
But it will ALSO put an IP in places you might not want right now.
ok that is fine. i will change the A record IP for mergelab.co once i get another server.
Just tried again and still failed
Challenge failed for domain www.live.mergelab.co
Challenge failed for domain live.mergelab.co
http-01 challenge for www.live.mergelab.co
http-01 challenge for live.mergelab.co
You have to be careful, since "live.mergelab.co" is a CNAME of "mergelab.co"
You should probably change the way that is being done.
k what do you recemend i do for live.mergelab.co ?
still fails when i run this command
sudo certbot --nginx -d live.mergelab.co -d www.live.mergelab.co
it even fails to get cert for www.mergelab.co even though i have that pointing to the oracle server
http-01 challenge for www.mergelab.co
Challenge failed for domain www.mergelab.co
An A record with the IP
OR
CNAME to "www.live.mergelab.co" [which has the IP]
We said:
So, if we are done with the DNS issue...
Please show the complete error message.
i do have an A record with the IP.
and a cname for live.mergelab.co - should i change this to www.live.mergelab.co
While "live" relies on the "@" record it is subject to change when that record changes.
sorry i have no idea what to do here.
i have my A records and CNAME in place it looks like it but my nginx server still cannot get SSL cert
That is problem #2.
Let's have a look at the output of:
nginx -T
ubuntu@owncast:~$ sudo nginx -T
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
        worker_connections 768;
        # multi_accept on;
http {
        # Basic Settings
        sendfile on;
        tcp_nopush on;
        tcp_nodelay on;
        keepalive_timeout 65;
        types_hash_max_size 2048;
        # server_tokens off;
        # SSL Settings
        ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
        ssl_prefer_server_ciphers on;
        # Logging Settings
        # Gzip Settings
        gzip on;
        # gzip_vary on;
        # gzip_proxied any;
        # gzip_comp_level 6;
        # gzip_buffers 16 8k;
        # gzip_http_version 1.1;
        # Virtual Host Configs
#mail {
#       # See sample authentication script at:
#       # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
#       # auth_http localhost/auth.php;
#       # pop3_capabilities "TOP" "USER";
#       # imap_capabilities "IMAP4rev1" "UIDPLUS";
#       server {
#               listen     localhost:110;
#               protocol   pop3;
#               proxy      on;
#       server {
#               listen     localhost:143;
#               protocol   imap;
#               proxy      on;
types {
    text/html                             html htm shtml;
    text/css                              css;
    text/xml                              xml;
    image/gif                             gif;
    image/jpeg                            jpeg jpg;
    application/javascript                js;
    application/atom+xml                  atom;
    application/rss+xml                   rss;
    text/mathml                           mml;
    text/plain                            txt;
    text/vnd.sun.j2me.app-descriptor      jad;
    text/vnd.wap.wml                      wml;
    text/x-component                      htc;
    image/png                             png;
    image/tiff                            tif tiff;
    image/vnd.wap.wbmp                    wbmp;
    image/x-icon                          ico;
    image/x-jng                           jng;
    image/x-ms-bmp                        bmp;
    image/svg+xml                         svg svgz;
    image/webp                            webp;
    application/font-woff                 woff;
    application/java-archive              jar war ear;
    application/json                      json;
    application/mac-binhex40              hqx;
    application/msword                    doc;
    application/pdf                       pdf;
    application/postscript                ps eps ai;
    application/rtf                       rtf;
    application/vnd.apple.mpegurl         m3u8;
    application/vnd.ms-excel              xls;
    application/vnd.ms-fontobject         eot;
    application/vnd.ms-powerpoint         ppt;
    application/vnd.wap.wmlc              wmlc;
    application/vnd.google-earth.kml+xml  kml;
    application/vnd.google-earth.kmz      kmz;
    application/x-7z-compressed           7z;
    application/x-cocoa                   cco;
    application/x-java-archive-diff       jardiff;
    application/x-java-jnlp-file          jnlp;
    application/x-makeself                run;
    application/x-perl                    pl pm;
    application/x-pilot                   prc pdb;
    application/x-rar-compressed          rar;
    application/x-redhat-package-manager  rpm;
    application/x-sea                     sea;
    application/x-shockwave-flash         swf;
    application/x-stuffit                 sit;
    application/x-tcl                     tcl tk;
    application/x-x509-ca-cert            der pem crt;
    application/x-xpinstall               xpi;
    application/xhtml+xml                 xhtml;
    application/xspf+xml                  xspf;
    application/zip                       zip;
    application/octet-stream              bin exe dll;
    application/octet-stream              deb;
    application/octet-stream              dmg;
    application/octet-stream              iso img;
    application/octet-stream              msi msp msm;
    application/vnd.openxmlformats-officedocument.wordprocessingml.document    docx;
    application/vnd.openxmlformats-officedocument.spreadsheetml.sheet          xlsx;
    application/vnd.openxmlformats-officedocument.presentationml.presentation  pptx;
    audio/midi                            mid midi kar;
    audio/mpeg                            mp3;
    audio/ogg                             ogg;
    audio/x-m4a                           m4a;
    audio/x-realaudio                     ra;
    video/3gpp                            3gpp 3gp;
    video/mp2t                            ts;
    video/mp4                             mp4;
    video/mpeg                            mpeg mpg;
    video/quicktime                       mov;
    video/webm                            webm;
    video/x-flv                           flv;
    video/x-m4v                           m4v;
    video/x-mng                           mng;
    video/x-ms-asf                        asx asf;
    video/x-ms-wmv                        wmv;
    video/x-msvideo                       avi;
# configuration file /etc/nginx/conf.d/www.live.mergelab.co.conf:
    listen 80 default_server;
    root /var/www/html;
    server_name www.live.mergelab.co;
# configuration file /etc/nginx/sites-enabled/default:
ubuntu@owncast:~$
I'm not sure we got all of that config.
What shows?:
ls -l /etc/nginx/sites-enabled/*
And you should probably deal with this too:
24 updates can be applied immediately.
To see these additional updates run: apt list --upgradable
