Sorry guys I'm beyond a total noob at this. I was following this How To Install Nextcloud On TrueNAS And Obtain SSL Certificate from Let’s Encrypt with Certbot - YouTube tutorial when i received the error
yeranossianstorage.xyz
certbot --nginx -d yeranossianstorage.xyz
Domain: yeranossianstorage.xyz
Type: dns
Detail: no valid A records found for yeranossianstorage.xyz; no valid AAAA records found for yeranossianstorage.xyz
