Nginx LE subdomain certbot-auto command not working
My domain is: foodtruck.paulbrimleywebdev.com
I ran this command: sudo certbot-auto certonly -a webroot --webroot-path=/var/www/foodtruck.paulbrimleywebdev.com -d foodtruck.paulbrimleywebdev.com
Failed authorization procedure. foodtruck.paulbrimleywebdev.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://foodtruck.paulbrimleywebdev.com/.well-known/acme-challenge/B0STL4Wi4SLEUvKfrE3I7GPSeHVbR_8fPnqhvsmGIrU [67.186.231.1]: 404
My operating system is (include version): ubuntu server 14.04 LTS
My web server is (include version): nginx version: nginx/1.4.6 (Ubuntu)
My hosting provider, if applicable, is: godaddy
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): ?
I have been able to get the certificate for paulbrimleywebdev.com and www.paulbrimleywebdev.com to work, but I can’t for the subdomain.
Nginx and GoDaddy screen shot:
I am new to all of this so don’t judge too harshly and thank you for your help :).
Try replacing your “location /.well-known/acme-challenge” and “location /.well-known” blocks with:
        root /var/www/paulbrimleywebdev.com;
and
        root /var/www/foodtruck.paulbrimleywebdev.com;
(By the way, it would be simpler to use the same root for all your acme-challenge directories, and only one certificate covering all of your subdomains.)
(Also, in future please use a pastebin instead of a screenshot.)
Thank you for your response. I tried the changes you suggested with the same results when running “sudo certbot-auto certonly -a webroot --webroot-path=/var/www/foodtruck.paulbrimleywebdev.com -d foodtruck.paulbrimleywebdev.com”:
Failed authorization procedure. foodtruck.paulbrimleywebdev.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://foodtruck.paulbrimleywebdev.com/.well-known/acme-challenge/YNJvv4tvb2yY_IAbKZfTpUGuDpEOJe5Ftg1Sbi74zaE [67.186.231.1]: 404
Any other ideas? Thank you!
The 404 pages in http://foodtruck.paulbrimleywebdev.com/.well-known/acme-challenge/ appear to be served by Express, same as the rest of the site. Files that exist may be handled differently, but nonexistent files are certainly not being handled consistently with the configuration screenshot.
I’d try to put a file in that directory and attempt to load it manually. See if that works. Try a file with an extension and one with no extension. Once you can get that working, then try certbot again.
and investigate your Nginx configuration and error.log
