Nginx error____
When commanded sudo certbot --nginx -d expmotion.com gives the following error http://joxi.ru/823z9QRfDaO0pm
IMG_20220421_134207_269
404...
  • are your A and AAAA records pointing to your server? double check, please
  • show us the output of nginx -T -- paste it on the forum between three backticks
like this
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
        worker_connections 768;
        # multi_accept on;
http {
        # Basic Settings
        sendfile on;
        tcp_nopush on;
        tcp_nodelay on;
        keepalive_timeout 65;
        types_hash_max_size 2048;
        # server_tokens off;
        # SSL Settings
        ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
        ssl_prefer_server_ciphers on;
        # Logging Settings
        # Gzip Settings
        gzip on;
        # gzip_vary on;
        # gzip_proxied any;
        # gzip_comp_level 6;
        # gzip_buffers 16 8k;
        # gzip_http_version 1.1;
        # Virtual Host Configs
#mail {
#       # See sample authentication script at:
#       # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
#       # auth_http localhost/auth.php;
#       # pop3_capabilities "TOP" "USER";
#       # imap_capabilities "IMAP4rev1" "UIDPLUS";
#       server {
#               listen     localhost:110;
#               protocol   pop3;
#               proxy      on;
#       server {
#               listen     localhost:143;
#               protocol   imap;
#               proxy      on;
types {
    text/html                             html htm shtml;
    text/css                              css;
    text/xml                              xml;
    image/gif                             gif;
    image/jpeg                            jpeg jpg;
    application/javascript                js;
    application/atom+xml                  atom;
    application/rss+xml                   rss;
    text/mathml                           mml;
    text/plain                            txt;
    text/vnd.sun.j2me.app-descriptor      jad;
    text/vnd.wap.wml                      wml;
    text/x-component                      htc;
    image/png                             png;
    image/tiff                            tif tiff;
    image/vnd.wap.wbmp                    wbmp;
    image/x-icon                          ico;
    image/x-jng                           jng;
    image/x-ms-bmp                        bmp;
    image/svg+xml                         svg svgz;
    image/webp                            webp;
    application/font-woff                 woff;
    application/java-archive              jar war ear;
    application/json                      json;
    application/mac-binhex40              hqx;
    application/msword                    doc;
    application/pdf                       pdf;
    application/postscript                ps eps ai;
    application/rtf                       rtf;
    application/vnd.apple.mpegurl         m3u8;
    application/vnd.ms-excel              xls;
    application/vnd.ms-fontobject         eot;
    application/vnd.ms-powerpoint         ppt;
    application/vnd.wap.wmlc              wmlc;
    application/vnd.google-earth.kml+xml  kml;
    application/vnd.google-earth.kmz      kmz;
    application/x-7z-compressed           7z;
    application/x-cocoa                   cco;
    application/x-java-archive-diff       jardiff;
    application/x-java-jnlp-file          jnlp;
    application/x-makeself                run;
    application/x-perl                    pl pm;
    application/x-pilot                   prc pdb;
    application/x-rar-compressed          rar;
    application/x-redhat-package-manager  rpm;
    application/x-sea                     sea;
    application/x-shockwave-flash         swf;
    application/x-stuffit                 sit;
    application/x-tcl                     tcl tk;
    application/x-x509-ca-cert            der pem crt;
    application/x-xpinstall               xpi;
    application/xhtml+xml                 xhtml;
    application/xspf+xml                  xspf;
    application/zip                       zip;
    application/octet-stream              bin exe dll;
    application/octet-stream              deb;
    application/octet-stream              dmg;
    application/octet-stream              iso img;
    application/octet-stream              msi msp msm;
    application/vnd.openxmlformats-officedocument.wordprocessingml.document    docx;
    application/vnd.openxmlformats-officedocument.spreadsheetml.sheet          xlsx;
    application/vnd.openxmlformats-officedocument.presentationml.presentation  pptx;
    audio/midi                            mid midi kar;
    audio/mpeg                            mp3;
    audio/ogg                             ogg;
    audio/x-m4a                           m4a;
    audio/x-realaudio                     ra;
    video/3gpp                            3gpp 3gp;
    video/mp2t                            ts;
    video/mp4                             mp4;
    video/mpeg                            mpeg mpg;
    video/quicktime                       mov;
    video/webm                            webm;
    video/x-flv                           flv;
    video/x-m4v                           m4v;
    video/x-mng                           mng;
    video/x-ms-asf                        asx asf;
    video/x-ms-wmv                        wmv;
    video/x-msvideo                       avi;
# configuration file /etc/nginx/sites-enabled/pixer:
    listen 80;
    server_name expmotion.com;
    add_header X-Frame-Options "SAMEORIGIN";
    add_header X-XSS-Protection "1; mode=block";
    add_header X-Content-Type-Options "nosniff";
    index index.html index.htm index.php;
    charset utf-8;
    # For API
    location /backend {
        alias /var/www/pixer-laravel/pixer-api/public;
        try_files $uri $uri/ @backend;
            location ~ \.php$ {
            include fastcgi_params;
            fastcgi_param SCRIPT_FILENAME $request_filename;
            fastcgi_pass   unix:/run/php/php7.4-fpm.sock;
   location @backend {
      rewrite /backend/(.*)$ /backend/index.php?/$1 last;
   # For FrontEnd
   location /{
        proxy_pass http://localhost:3000;
        proxy_http_version 1.1;
        proxy_set_header Connection 'upgrade';
        proxy_set_header Host $host;
        proxy_cache_bypass $http_upgrade;
    location /admin{
        proxy_pass http://localhost:3002/admin;
    error_page 404 /index.php;
    location ~ \.php$ {
        fastcgi_pass unix:/var/run/php/php7.4-fpm.sock;
        fastcgi_index index.php;
        fastcgi_param SCRIPT_FILENAME $realpath_root$fastcgi_script_name;
    location ~ /\.(?!well-known).* {
        deny all;
# configuration file /etc/nginx/fastcgi_params:
fastcgi_param  QUERY_STRING       $query_string;
fastcgi_param  REQUEST_METHOD     $request_method;
fastcgi_param  CONTENT_TYPE       $content_type;
fastcgi_param  CONTENT_LENGTH     $content_length;
fastcgi_param  SCRIPT_NAME        $fastcgi_script_name;
fastcgi_param  REQUEST_URI        $request_uri;
fastcgi_param  DOCUMENT_URI       $document_uri;
fastcgi_param  DOCUMENT_ROOT      $document_root;
fastcgi_param  SERVER_PROTOCOL    $server_protocol;
fastcgi_param  REQUEST_SCHEME     $scheme;
fastcgi_param  HTTPS              $https if_not_empty;
fastcgi_param  GATEWAY_INTERFACE  CGI/1.1;
fastcgi_param  SERVER_SOFTWARE    nginx/$nginx_version;
fastcgi_param  REMOTE_ADDR        $remote_addr;
fastcgi_param  REMOTE_PORT        $remote_port;
fastcgi_param  SERVER_ADDR        $server_addr;
fastcgi_param  SERVER_PORT        $server_port;
fastcgi_param  SERVER_NAME        $server_name;
# PHP only, required if PHP was built with --enable-force-cgi-redirect
fastcgi_param  REDIRECT_STATUS    200;
You have a series of location blocks but no default.
see if this can help: Pitfalls and Common Mistakes | NGINX
IPv6 and IPv4 not equal:
curl -Ii6 expmotion.com
HTTP/1.1 403 Forbidden
Connection: close
Content-Type: text/html
Cache-Control: no-cache
X-Frame-Options: SAMEORIGIN
X-XSS-Protection: 1; mode=block
X-Content-Type-Options: nosniff
Content-Security-Policy: frame-ancestors 'self'
Content-Length: 3447
curl -Ii4 expmotion.com
HTTP/1.1 200 OK
Date: Fri, 22 Apr 2022 02:08:27 GMT
Server: Apache/2.4.41 (Ubuntu)
Last-Modified: Fri, 21 Aug 2020 12:09:48 GMT
ETag: "2aa6-5ad621d04a000"
Accept-Ranges: bytes
Content-Length: 10918
Vary: Accept-Encoding
curl -Ii6 expmotion.com/.well-known/acme-challenge/Test_File-1234
Connection: close
Content-Length: 3488
curl -Ii4 expmotion.com/.well-known/acme-challenge/Test_File-1234
HTTP/1.1 404 Not Found
Date: Fri, 22 Apr 2022 02:10:16 GMT
Thanks my friend
