Nginx - certbot - chain not updating
I have made the folowing directories and file
sudo mkdir /apps/www/html/.well-known
sudo mkdir /apps/www/html/.well-known/acme-challenge
echo "YAY!" > /apps/www/html/.well-known/acme-challenge/Test-File-1234
http://atif.hippochat.io/.well-known/acme-challenge/Test-File-1234
the url download the file
I have made the following folders and file
It now downloads the file.
Perfect I can see the test file:
wget http://atif.hippochat.io/.well-known/acme-challenge/Test-File-1234 --no-check-certificate
--2021-10-06 22:05:55--  http://atif.hippochat.io/.well-known/acme-challenge/Test-File-1234
Resolving atif.hippochat.io (atif.hippochat.io)... 54.213.183.207
Connecting to atif.hippochat.io (atif.hippochat.io)|54.213.183.207|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://atif.hippochat.io/.well-known/acme-challenge/Test-File-1234 [following]
--2021-10-06 22:05:55--  https://atif.hippochat.io/.well-known/acme-challenge/Test-File-1234
Connecting to atif.hippochat.io (atif.hippochat.io)|54.213.183.207|:443... connected.
WARNING: cannot verify atif.hippochat.io's certificate, issued by ‘CN=Sectigo RSA Domain Validation Secure Server CA,O=Sectigo Limited,L=Salford,ST=Greater Manchester,C=GB’:
  Unable to locally verify the issuer's authority.
WARNING: no certificate subject alternative name matches
        requested host name ‘atif.hippochat.io’.
HTTP request sent, awaiting response... 200 OK
Length: 4 [application/octet-stream]
Saving to: ‘Test-File-1234’
Test-File-1234                         100%[==========================================================================>]       4  --.-KB/s    in 0s
2021-10-06 22:05:56 (501 KB/s) - ‘Test-File-1234’ saved [4/4]
cat Test-File-1234
YAY
Now try to get a cert from the staging environment (use --dry-run).
Simulating a certificate request for atif.hippochat.io
http-01 challenge for atif.hippochat.io
Challenge failed for domain atif.hippochat.io
Domain: atif.hippochat.io
Detail: Invalid response from https://atif.hippochat.io/.well-known/acme-challenge/BCoVAi5CPPybQywVn2TdQ9b8gVlL2M-D7gzuytrFWbs [54.213.183.207]: "\r\n404 Not Found\r\n\r\n
404 Not Found
\r\n
nginx\r\n"
Then the certbot --nginx plugin is unable to find the correct path where to place the challenge file.
Please show the LE log file.
It should shed light on the problem.
OR
You could hobble on with whatever is wrong (likely within the nginx config) and switch from using:
"certonly --nginx"
to
"certonly --webroot -w /apps/www/html"
@rg305
Thanks mate , webroot helped to solve this.
Glad to have helped :slight_smile:
Cheers from Miami :beers:
#FreeCUBA :cuba:
