Happy to read that. You have rechecked your domain, now I see a Grade E.
Both connections are secure, no loop, no http status 500. The certificate has both domain names and is 87 days valide.
Later you may change the details: Correct redirect (Grade A, not E) and only one http status 200 as result (one preferred version).
hkim009
February 10, 2019, 2:57am
42
Ah, got it to grade C. But this alludes me:
C Error - more then one version with Http-Status 200
Any suggestions?
You don't have a preferred version:
So some users read the https + non-www, other the https + www - version, users may add links to both versions, search engines may spider both, so you have duplicated content.
So choose one version as the preferred version.
And add a redirect https + not-preferred-version -> https + preferred-version.
4 urls, three redirects, at the end, every user has the same site.
Compare it with other sites who has a www and a non-www dns entry and grade A or B.
hkim009
February 10, 2019, 11:22pm
44
First: very grateful for all the help!
Now, I understand what I have to do but not how I should go on with this. I have following nginx config:
#redirect all www to non-ww
server_name www.psykolog.nu;
ssl_certificate /location ;
ssl_certificate_key /location;
include /etc/letsencrypt/options-ssl-nginx.conf;
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem;
listen *:80;
listen *:443 ssl;
listen [::]:80 ipv6only=on;
listen [::]:443 ssl ipv6only=on;
return 301 https://psykolog.nu$request_uri;
# Redirect all non-encrypted to encrypted
server_name psykolog.nu;
listen *:80;
listen [::]:80;
#main
listen 443 ssl default_server;
listen [::]:443 ssl default_server;
ssl_certificate /location;
root /location;
try_files $uri $uri/ =404;
Why do I still get:
āC Error - more then one version with Http-Status 200ā?
rg305
February 10, 2019, 11:34pm
45
SIte: https://www.psykolog.nu/
fails to redirect.
Change:
#redirect all www to non-www
listen *:80;
listen *:443 ssl;
into two separate blocks:
[and adjust the redirection to be more as expected]
#redirect all www to non-www 80
listen *:80;
return 301 https://www.psykolog.nu$request_uri;
#redirect all www to non-www 443
listen *:443 ssl;
This definition
isn't used. If this block would be used, my tool would see a redirect http + www -> https + non-www, that would be a Grade E.
But you don't have a Grade E. Your last check ( psykolog.nu - Make your website better - DNS, redirects, mixed content, certificates ):
So you have a second server with the same server name (or the default) and port 443 without a redirect.
