My domain is: psykolog.nu
I ran this command: curl -v https://psykolog.nu
t# curl -v https://psykolog.nu
- Rebuilt URL to: https://psykolog.nu/
- Trying 127.0.0.1…
- TCP_NODELAY set
- Connected to psykolog.nu (127.0.0.1) port 443 (#0)
- ALPN, offering h2
- ALPN, offering http/1.1
- successfully set certificate verify locations:
- CAfile: /etc/ssl/certs/ca-certificates.crt
CApath: /etc/ssl/certs - (304) (OUT), TLS handshake, Client hello (1):
- OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to psykolog.nu:443
- Closing connection 0
curl: (35) OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to psykolog.nu:443
My web server is (include version): Nginx 1.14.0
Ubuntu 18.04 LTS
No, but I am using Easy Engine 4
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): Certbot 0.28.0
I’ve create my site using Easy Engine 4. Everything seems to be fine but it seems that my certificate only inludes ‘psykolog.nu’ and not ‘www.psykolog.nu’. From the error curl is displaying it may also be some other misconfiguration with nginx config?
I tried to expand the certificate to include www.psykolog.nu with:
certbot --webroot -w /webroot_folder/ certonly -d psykolog.nu -d www.psykolog.nu but it results in following error:
An unexpected error occurred:
There were too many requests of a given type :: Error finalizing order :: too many certificates already issued for exact set of domains: psykolog.nu,www.psykolog.nu: see https://letsencrypt.org/docs/rate-limits/
Looking at https://tools.letsdebug.net/cert-search?m=domain&q=psykolog.nu&d=168 verifies that I indeed have created too many duplicates.
I can try again tomorrow (when the ceritifcate can be issued again due to rate-limit) but am I doing right regarding the certbot command? Will this remove the error I get when I run curl -v https://psykolog.nu?
