/www.spoopytripwire.com/
/etc/httpd/sites-available/tripwire.conf: ServerName www.spoopytripwire.co m
/etc/httpd/sites-available/tripwire.conf: ServerAlias spoopytripwire.com
/etc/httpd/sites-available/tripwire.conf:RewriteCond %{SERVER_NAME} =www.spoopyt ripwire.com [OR]
/etc/httpd/sites-available/tripwire.conf:RewriteCond %{SERVER_NAME} =spoopytripw ire.com
/etc/httpd/sites-available/tripwire-le-ssl.conf: ServerName spoopytripwir e.com
/etc/httpd/sites-available/tripwire-le-ssl.conf: ServerAlias www.spoopytr ipwire.com
/etc/httpd/sites-available/tripwire-le-ssl.conf:SSLCertificateFile /etc/letsencr ypt/live/spoopytripwire.com/cert.pem
/etc/httpd/sites-available/tripwire-le-ssl.conf:SSLCertificateKeyFile /etc/letse ncrypt/live/spoopytripwire.com/privkey.pem
/etc/httpd/sites-available/tripwire-le-ssl.conf:SSLCertificateChainFile /etc/let sencrypt/live/spoopytripwire.com/chain.pem
/etc/httpd/sites-enabled/tripwire.conf: ServerName www.spoopytripwire.com
/etc/httpd/sites-enabled/tripwire.conf: ServerAlias spoopytripwire.com
/etc/httpd/sites-enabled/tripwire.conf:RewriteCond %{SERVER_NAME} =www.spoopytri pwire.com [OR]
/etc/httpd/sites-enabled/tripwire.conf:RewriteCond %{SERVER_NAME} =spoopytripwir e.com
/etc/httpd/sites-enabled/tripwire-le-ssl.conf: ServerName spoopytripwire.com
/etc/httpd/sites-enabled/tripwire-le-ssl.conf: ServerAlias www.spoopytripwire.c om
/etc/httpd/sites-enabled/tripwire-le-ssl.conf:SSLCertificateFile /etc/letsencryp t/live/spoopytripwire.com/cert.pem
/etc/httpd/sites-enabled/tripwire-le-ssl.conf:SSLCertificateKeyFile /etc/letsenc rypt/live/spoopytripwire.com/privkey.pem
/etc/httpd/sites-enabled/tripwire-le-ssl.conf:SSLCertificateChainFile /etc/letse ncrypt/live/spoopytripwire.com/chain.pem
There was more put its mostly some stuff in the error logs we're not concerned with (a twitter integration isnt properly setup)
I'm not sure how to remove teh ssl.conf file without making the site inaccessible, when I remove it httpd will start but the page wont load
