Need to renew wildcard certificate with domain managed by Godaddy
I need to renew my wildcard certificate. My domain is manged & hosted by Godaddy.
Can i do this with certbot renew command?
If Yes, then do i have to update the TXT record and will there be any update i need to do with my subdomian certificates created from my wildcard certificate?
My domain is: obotworld-videoplatform.com
My web server is (include version): I am using JKS certificates
The operating system my web server runs on is (include version): Centos 7
My hosting provider, if applicable, is: GoDaddy
Most likely you manually created the TXT record, right? In this case, you cannot use certbot renew .
You must use the certonly command (like you did the first time):
certbot certonly -d "obotworld-videoplatform.com" -d "*.obotworld-videoplatform.com" -a manual --preferred-challenges dns
By the way, there is an alternative to using Certbot that supports wildcard certificates + automatic renewal via GoDaddy DNS: https://github.com/Neilpang/acme.sh/tree/master/dnsapi#4-use-godaddycom-domain-api-to-automatically-issue-cert
Thanks for the reply.
One more thing:
If i am renewing certificate with the command
"certbot certonly -d “obotworld-videoplatform.com” -d “*.obotworld-videoplatform.com” -a manual --preferred-challenges dns"
Is there anything i need to change on my subdomain certificates? I have 2 3 subdomain JKS certs for this wildcard domain.
Thanks in Advance
I'm not sure what you mean.
If you use this certificate somewhere that requires a JKS-format certificate, then you need to convert the renewed certificate PEM (fullchain.pem and privkey.pem) into JKS format, after each renewal. This is because the renewed certificate is technically a completely new and distinct certificate.
For this reason, it's preferable to use automation rather than manually doing stuff.
