My domain is: https://www.ittv.in/
i have to downgrade tls 1.2 from tls 1.3
installed successfully using this client https://acme-v02.api.letsencrypt.org/directory
nginx ingress controller
azure kuberenete service v1.19
Azure Cloud
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): ACME v2 Production Environment
That's not an ACME client, but the ACME API a client would be able to connect to. Which client are you using exactly? Depending on your client it may or may not have an option to disable TLSv1.3. Please refer to the documentation of said client.
Thanks for info. We are getting let'sencrypt production certificate from cluster issuer. Is there any possible to enable tls. 1.2 using certbot client.
I have no idea what "cluster issuer" is, but if you're not using Certbot as a client, I would not recommend using Certbot just to change the TLS version.
By the way, the DNS of your domain is down. I'm getting a "REFUSED" error back from the Azure DNS servers when requesting them for ittv.in or www.ittv.in.
