Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: www.gryphontraining.co.uk
I ran this command: n/a
It produced this output: n/a
My web server is (include version): linux
The operating system my web server runs on is (include version): Apache Version 2.2.31
My hosting provider, if applicable, is: HostNine
I can login to a root shell on my machine (yes or no, or I don’t know): NO
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): YES
or certbot-auto --version
if you’re using Certbot): n/a
Hi @BuyLikeMe
then your options are limited. Your hoster or your control panel should support Letsencrypt.
Which control panel do you use? Is there an integrated solution?
But that
looks your hoster doesn't support a Letsencrypt solution.
Checked your domain you have already Letsencrypt certificates ( https://check-your-website.server-daten.de/?q=gryphontraining.co.uk ):
CRT-Id
Issuer
not before
not after
Domain names
LE-Duplicate
next LE
1245960409
CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US
2019-02-28 13:08:31
2019-05-29 12:08:31
1 entries
758444559
2018-08-28 08:20:12
2018-11-26 09:20:12
gryphontraining.co.uk , www.gryphontraining.co.uk
2 entries
And you use one:
CN=gryphontraining.co.uk
28.02.2019
29.05.2019
expires in 37 days gryphontraining.co.uk - 1 entry
How did you create that certificate? Do that again. And add the www-version, so both versions are secure.
system
closed
May 22, 2019, 8:01pm
#4
