I have been trying to generate ssl certificates and setup my nginx but keep running into the acme-challenge error, am i doing something really stupid:
This is my conf:
listen 80;
server_name chat.hyperlabs.tools;
proxy_pass http://localhost:32001;
sudo certbot certonly --nginx -d chat.hyperlabs.tools --dry-run
Simulating a certificate request for chat.hyperlabs.tools
Domain: chat.hyperlabs.tools
Detail: 23.88.118.129: Invalid response from http://chat.hyperlabs.tools/.well-known/acme-challenge/tT6pM4nmgYg3F9FJ3LT-fgY-o0ch-CLH3tIWcWRZOA0: 404
A 404 error with the --nginx plug-in as authenticator is not that common.
That plug-in adds temp code to your nginx; then reloads nginx and requests a cert. The Let's Encrypt server then sends an HTTP request to the IP in the public DNS looking for the info from that temp change. If the proper info is returned the cert is issued. In this case 404 means it was not found so failed.
It would have been helpful to see the answers to the other questions on the form you should have been shown.
This usually works very well. But, unusual nginx configs or problems with your local comms config can break it.
Can you upload the output of the below command? Use the upload button on the post menu
sudo nginx -T >config.txt
A capital T is essential. Upload the resulting large config.txt file
UPDATE:
Oh, I just realized you have a "Kubernetes Fake Certificate" being used for HTTPS requests to this domain name. Can you explain K8s role in your setup?
How did you find out about my k8s.
So k8s in this case runs my frontend so i can deploy more apps on the same server.
Also i have a backend server which runs on k8s which i will also need to generate nginx ssl certificates. I use k8s so i can trigger jobs.
Is the setup different for k8s deployments
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
types_hash_max_size 2048;
# server_tokens off;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# Virtual Host Configs
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
# configuration file /etc/nginx/modules-enabled/50-mod-http-geoip2.conf:
load_module modules/ngx_http_geoip2_module.so;
# configuration file /etc/nginx/modules-enabled/70-mod-stream-geoip2.conf:
load_module modules/ngx_stream_geoip2_module.so;
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/png png;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
image/svg+xml svg svgz;
image/webp webp;
application/font-woff woff;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.wap.wmlc wmlc;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
application/vnd.openxmlformats-officedocument.wordprocessingml.document docx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet xlsx;
application/vnd.openxmlformats-officedocument.presentationml.presentation pptx;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
# configuration file /etc/nginx/sites-enabled/api.chat:
listen 80;
server_name api.chat.hyperlabs.tools;
proxy_pass http://localhost:31000;
proxy_set_header Host $host;
# configuration file /etc/nginx/sites-enabled/chat.hyperlabs.tools:
listen 80;
# configuration file /etc/nginx/sites-enabled/default:
# https://www.nginx.com/resources/wiki/start/
# https://www.nginx.com/resources/wiki/start/topics/tutorials/config_pitfalls/
# https://wiki.debian.org/Nginx/DirectoryStructure
# In most cases, administrators will remove this file from sites-enabled/ and
# leave it as reference inside of sites-available where it will continue to be
# updated by the nginx packaging team.
# This file will automatically load configuration files provided by other
# applications, such as Drupal or Wordpress. These applications will be made
# available underneath a path with that package name, such as /drupal8.
listen 80 default_server;
# SSL configuration
root /var/www/html;
server_name _;
try_files $uri $uri/ =404;
#location ~ \.php$ {
# include snippets/fastcgi-php.conf;
# # With php-fpm (or other unix sockets):
# fastcgi_pass unix:/run/php/php7.4-fpm.sock;
# # With php-cgi (or other tcp sockets):
# fastcgi_pass 127.0.0.1:9000;
# concurs with nginx's one
#location ~ /\.ht {
# deny all;
#server {
# listen 80;
# listen [::]:80;
# server_name example.com;
# root /var/www/example.com;
# index index.html;
# location / {
# try_files $uri $uri/ =404;
On a whim I tried using HTTPS for your domain. I saw the cert which is exchanged with any client using HTTPS (such as at this SSL Checker site )
Yes, very much so.
I changed the title to alert other volunteers who want to help with K8s advice.
Thanks for the help, atleast i know what to research to fix this
I think people usually use cert-manager, not certbot, with K8s but I do not know all of the possibilities
rg305
October 3, 2023, 12:53am
8
Very strange indeed!
What version of certbot are you using?
certbot --version
The default_server is bound to IPv4 and IPv6... but this FQDN only has IPv4 - so that's a non-issue.
Seen:
I would try adding a dedicated location for the expected ACME challenge requests.
location /.well-known/acme-challenge
And then place a sample test file in that location to see if it can be reached from the Internet:
http://chat.hyperlabs.tools/.well-known/acme-challenge/{TestFileName}
If so, then you could use --webroot to bypass whatever if failing with the --nginx plugin.
If not, then that would explain why this are failing and gives you an easy way to test it - while you make changes [until you get that fixed].
