Need Help with Certificate Renewal Issue
Hello,
I am encountering an issue with renewing my SSL certificates using Certbot on my EC2 instance running Ubuntu 22.04.
My domain is: admin-agg.mm.app-kfc.com (13.56.83.246)
I ran this command: sudo certbot --nginx
It produced this output: ValueError: Requesting acme-v02.api.letsencrypt.org/directory: Network is unreachable
My web server is: nginx/1.18.0 (Ubuntu)
The operating system my web server runs on is: Ubuntu 22.04.4 LTS
My hosting provider, if applicable, is: AWS EC2 instance
The version of my client is: certbot 2.11.0.
2024-07-14_15-26
First, the Let's Encrypt ACME API only supports HTTPS. Your example curl was trying HTTP (and mistakenly included the name traceroute).
I think something may be set wrong in your EC2 Security Group. Check your permissions for port 443 - both inbound and outbound rules. I can't reach your domain using HTTPS not even to be told it had an expired cert. HTTP (port 80) works fine.
If you don't see anything wrong there, please show result of these
curl -4 https://acme-v02.api.letsencrypt.org/directory
curl -6 https://acme-v02.api.letsencrypt.org/directory
sudo traceroute -T -p443 acme-v02.api.letsencrypt.org
And also
curl -I https://google.com
curl https://cloudflare.com/cdn-cgi/trace
Hello,
Thank you for your response. Yes, we also tried with HTTPS. I am sharing screenshots of each command:
Thanks.
The IPv4 address for the LE API is 172.65.32.248 (today)
There is a range of private IP addresses that start with 172. But, that should only be for the range 172.16.0.0/12.
If you setup your local network (wrongly) to use, say, 172.0.0.0/8 that declares a wider range of IP addresses as private. Your local network won't then route requests for these extra IP to the public internet. The acme-v02 IP is between /8 and /12 so you won't be able to reach it.
I think that is what is happening here as shown by the traceroute never reaching even the public internet.
netstat -nr
ARIN Explanation: IPv4 Private Address Space and Filtering - American Registry for Internet Numbers
See AWS docs for Route Table Configuration
