My domain is: monitoring.neurones-it.asia
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated) (Enter âcâ to cancel): monitoring.neurones-it.asia
http-01 challenge for monitoring.neurones-it.asia
Job for httpd.service invalid.
Unable to restart apache using [âapachectlâ, âgracefulâ]
Error while running apachectl restart.
Job for httpd.service failed because the control process exited with error code. See âsystemctl status httpd.serviceâ and âjournalctl -xeâ for details.
Encountered exception during recovery:
File â/usr/lib/python2.7/site-packages/certbot/_internal/error_handler.pyâ, line 125, in _call_registered
self.funcs-1
File â/usr/lib/python2.7/site-packages/certbot/_internal/auth_handler.pyâ, line 243, in _cleanup_challenges
self.auth.cleanup(achalls)
File â/usr/lib/python2.7/site-packages/certbot_apache/_internal/configurator.pyâ, line 2530, in cleanup
self.restart()
File â/usr/lib/python2.7/site-packages/certbot_apache/_internal/configurator.pyâ, line 2400, in restart
self._reload()
File â/usr/lib/python2.7/site-packages/certbot_apache/_internal/configurator.pyâ, line 2427, in _reload
raise errors.MisconfigurationError(error)
MisconfigurationError: Error while running apachectl restart.
Unable to find a virtual host listening on port 80 which is currently needed for Certbot to prove to the CA that you control your domain. Please add a virtual host for port 80.
My web server is (include version): httpd24
The operating system my web server runs on is (include version): centos 7
I can login to a root shell on my machine (yes or no, or I donât know): yes
Iâm using a control panel to manage my site (no, or provide the name and version of the control panel): no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if youâre using Certbot): certbot 1.5.0
