admin@OpenVpn:~$ curl -I vpn.sammzinc.com/.well-known/acme-challenge/ForumTest
HTTP/1.1 404 Not Found
Server: nginx
Date: Sat, 16 Apr 2022 21:26:43 GMT
Content-Type: text/html
Content-Length: 3212
Keep-Alive: timeout=20
Vary: Accept-Encoding
ETag: "608a73aa-c8c"
I don't know if you want the commercial offering of openvpn.
If you can work with the community version (which also makes pointless the use of a Let's Encrypt certificate), check these projects:
- GitHub - Nyr/openvpn-install: OpenVPN road warrior installer for Ubuntu, Debian, AlmaLinux, Rocky Linux, CentOS and Fedora
- GitHub - angristan/openvpn-install: Set up your own OpenVPN server on Debian, Ubuntu, Fedora, CentOS or Arch Linux.
(There are similar projects for wireguard, but wireguard is easy enough to setup without)
Hi All,
Thank you for all your help, I finally found and issue, I made a small mistake in firewall NAT rules. It's now fixed and it's working great.
Thanks
Sam
