my subdomain is point to correct IP address, also when I do nslookup for my subdomain it is resolving to correct IP address.
Please advice.
I am trying to secure my openvpn server vpn.sammzinc.com, using cloudflare for DNS service. A record is pointing for correct IP address.
I am using the following guide to obtain ssl certificate. OpenVPN Access Server & Lets Encrypt
now I get this error.
An unexpected error occurred:
There were too many requests of a given type :: Error creating new order :: too many failed authorizations recently: see Rate Limits - Let's Encrypt
when I run netstat -anpe | grep "80" | grep "LISTEN"
(Not all processes could be identified, non-owned process info
will not be shown, you would have to be root to see it all.)
unix 2 [ ACC ] STREAM LISTENING 11724980 - private/scalemail-backend
I am really new to linux, is above response to your question?
Also in my firewall. port 80 is open for vpn server.
open vpn
problem with wireguard, i am not able to access some of the subnet on my lan
example: my main lan subnet is 192.168.100.0/24
but there are some subnet on my network 192.168.15.0/24. when i connect to my wireguard, i can't access anything on 192.168.15.0/24 subnet
