I only asked for you to install acme.sh.
ONLY INSTALL
Is it installed?
Please show:
sudo /root/.acme.sh/acme.sh version
v3.0.0
Perfect, now you have an ACMEv2 compatible client installed.
Now lets try to use it to get the cert you need...
We will replace this certbot plan with acme.sh
Try:
apachectl -k stop
/root/.acme.sh/acme.sh --issue --standalone -d your.mail.domain -m your.email.address
apachectl -k start
apachectl -k stop
httpd (no pid file) not running
/root/.acme.sh/acme.sh --issue --standalone -d mail.ivanovoobl.ru -m it@ivanovoobl.ru
[Сб июл 31 00:11:25 MSK 2021] Using CA: https://acme.zerossl.com/v2/DV90
[Сб июл 31 00:11:25 MSK 2021] Standalone mode.
[Сб июл 31 00:11:25 MSK 2021] Single domain='mail.ivanovoobl.ru'
[Сб июл 31 00:11:25 MSK 2021] Getting domain auth token for each domain
[Сб июл 31 00:11:28 MSK 2021] Getting webroot for domain='mail.ivanovoobl.ru'
[Сб июл 31 00:11:28 MSK 2021] Verifying: mail.ivanovoobl.ru
[Сб июл 31 00:11:28 MSK 2021] Standalone mode server
[Сб июл 31 00:11:29 MSK 2021] Processing, The CA is processing your order, please just wait. (1/30)
[Сб июл 31 00:11:32 MSK 2021] Processing, The CA is processing your order, please just wait. (2/30)
[Сб июл 31 00:11:35 MSK 2021] Processing, The CA is processing your order, please just wait. (3/30)
[Сб июл 31 00:11:38 MSK 2021] Processing, The CA is processing your order, please just wait. (4/30)
[Сб июл 31 00:11:41 MSK 2021] Processing, The CA is processing your order, please just wait. (5/30)
[Сб июл 31 00:11:43 MSK 2021] Processing, The CA is processing your order, please just wait. (6/30)
[Сб июл 31 00:11:46 MSK 2021] Processing, The CA is processing your order, please just wait. (7/30)
[Сб июл 31 00:11:49 MSK 2021] Processing, The CA is processing your order, please just wait. (8/30)
[Сб июл 31 00:11:52 MSK 2021] Processing, The CA is processing your order, please just wait. (9/30)
[Сб июл 31 00:11:55 MSK 2021] Processing, The CA is processing your order, please just wait. (10/30)
[Сб июл 31 00:11:58 MSK 2021] Processing, The CA is processing your order, please just wait. (11/30)
[Сб июл 31 00:12:01 MSK 2021] Processing, The CA is processing your order, please just wait. (12/30)
[Сб июл 31 00:12:03 MSK 2021] Processing, The CA is processing your order, please just wait. (13/30)
[Сб июл 31 00:12:06 MSK 2021] Processing, The CA is processing your order, please just wait. (14/30)
[Сб июл 31 00:12:09 MSK 2021] Processing, The CA is processing your order, please just wait. (15/30)
[Сб июл 31 00:12:12 MSK 2021] Processing, The CA is processing your order, please just wait. (16/30)
[Сб июл 31 00:12:14 MSK 2021] Processing, The CA is processing your order, please just wait. (17/30)
[Сб июл 31 00:12:17 MSK 2021] Processing, The CA is processing your order, please just wait. (18/30)
[Сб июл 31 00:12:20 MSK 2021] Processing, The CA is processing your order, please just wait. (19/30)
[Сб июл 31 00:12:23 MSK 2021] Processing, The CA is processing your order, please just wait. (20/30)
[Сб июл 31 00:12:26 MSK 2021] Processing, The CA is processing your order, please just wait. (21/30)
[Сб июл 31 00:12:29 MSK 2021] Processing, The CA is processing your order, please just wait. (22/30)
[Сб июл 31 00:12:31 MSK 2021] Processing, The CA is processing your order, please just wait. (23/30)
[Сб июл 31 00:12:34 MSK 2021] Processing, The CA is processing your order, please just wait. (24/30)
[Сб июл 31 00:12:37 MSK 2021] Processing, The CA is processing your order, please just wait. (25/30)
[Сб июл 31 00:12:40 MSK 2021] Processing, The CA is processing your order, please just wait. (26/30)
[Сб июл 31 00:12:42 MSK 2021] Processing, The CA is processing your order, please just wait. (27/30)
[Сб июл 31 00:12:45 MSK 2021] Processing, The CA is processing your order, please just wait. (28/30)
[Сб июл 31 00:12:48 MSK 2021] Processing, The CA is processing your order, please just wait. (29/30)
[Сб июл 31 00:12:51 MSK 2021] mail.ivanovoobl.ru:Timeout
[Сб июл 31 00:12:51 MSK 2021] Please add '--debug' or '--log' to check more details.
[Сб июл 31 00:12:51 MSK 2021] See: How to debug acme.sh · acmesh-official/acme.sh Wiki · GitHub
Apache did not stop?
[it must first stop]
How do you stop Apache?
This is also a bit of a problem here:
it is not running as I mentioned earlier
I know what you said.
But something is still there:
curl -Iki http://mail.ivanovoobl.ru/
HTTP/1.1 503 Service Temporarily Unavailable
Date: Fri, 30 Jul 2021 21:50:27 GMT
Connection: close
so what to do?
Follow the packets...
How does the Internet reach your server?
How do you know that Apache is not running?
Please show:
sudo ps -ef | grep -Ei 'apache|http' | grep -v grep
sudo netstat -pant | grep -E '80|443'
tcp 0 0 192.168.110.8:143 192.168.110.21:58020 ESTABLISHED 43357/imap
tcp 0 0 192.168.110.8:143 192.168.110.21:58015 ESTABLISHED 43349/imap
tcp 0 0 192.168.110.8:143 192.168.110.188:57585 ESTABLISHED 64806/imap
tcp 0 0 192.168.110.8:143 176.59.51.64:20280 ESTABLISHED 18441/imap
tcp 0 0 192.168.110.8:22 192.168.110.203:14080 ESTABLISHED 48681/sshd
tcp 0 0 192.168.110.8:143 192.168.110.21:58013 ESTABLISHED 43348/imap
I also don't see any Apache running.
So, whatever is responding with "503" is likely part of the problem.
What does your server plug into?
I didn't quite understand your question
so what should I do?
You need to find the device that is responding to HTTP (with the 503 error).
Once found, you can begin to understand how to reconfigure it to your needs.
I did not set up this "kitchen" could you explain what exactly to look for and look for
Follow the wires.
What does that plug into?
[how to do reach the Internet - how does it reach you?]
tell me what ip and what domain name to specify in the dns record so that my server can reach the letsencrypt resource because there is no connection between them then the command
Â
sudo certbot certonly --manual --manual-public-ip-logging-ok --preferred-challenges dns-01 --server https://acme-v02.api.letsencrypt.org/directory -d mail.ivanovoobl.ru -m it@ivanovoobl.ru
Â
What do you mean?
Please show any error or message.
