Need help understanding the /etc/letsencrypt/my.conf file
I have everything working for a single subdomain and now I would like to configure things for several subdomains, but I am a little confused as to how I should setup the /etc/letsencrypt/my.conf file.
Should this file be able to handle more than 1 subdomain using [[webroot_map]] or do I need to create multiple files?
my.conf looks something like this:
version = 2.9.0
archive_dir = /etc/letsencrypt/archive/sub1.domain.tld
cert = /etc/letsencrypt/live/sub1.domain.tld/cert.pem
privkey = /etc/letsencrypt/live/sub1.domain.tld/privkey.pem
chain = /etc/letsencrypt/live/sub1.domain.tld/chain.pem
fullchain = /etc/letsencrypt/live/sub1.domain.tld/fullchain.pem
[renewalparams]
account = XXXXXXXXXXXXXXXXXX
authenticator = webroot
webroot_path = /var/www/sub1,
key_type = ecdsa
[[webroot_map]]
sub1.domain.tld = /var/www/sub1
If I wanted to add sub2.domain.tld and sub3.domain.tld to this configuration, how would I do it? I understand the [[webroot_map]] part which is I assume I can setup something like:
[[webroot_map]]
sub2.domain.tld = /var/www/sub2
sub3.domain.tld = /var/www/sub3
What is confusing me is the first part with the archive_dir =, cert =, pirvkey =, etc. I would assume that these files need to be unique for each cert but then why would there be [[webroot_map]]? Can these locations at the start of my config be configured to cover sub1-3? Should I create 3 different files? I am kind of lost and the documentation isn't very detailed when it comes to the conf file.
Because one cert can have up to 100 SAN entries.
Each of those entries can be located in its' own directory.
Each name could require its' own specific webroot path.
[unless all names point to the same path - all domains serve the exact same content]
[possible... but unlikely]
They should cover only one cert.
Note: One cert can have up to 100 SAN entries [names] in it.
It is not intended to be directly manipulated by Humans - LOL
It can be... But I'd leave that to the certbots of the [Internet] world.
Not by editing the renewal configuration manually, just run Certbot again, but now also with the hostnames you want to have added.
This is kind of a pain because I am trying to use the certbot docker container to do all of this so I was kind of hoping I could setup a config and just have it run certbot renew as the entry point and stop.
I ran certbot certonly -d sub1.domain.tld,sub2.domain.tld,sub3.domain.tld and that appears to have worked. If I now run certbot renew will it just auto-magically renew all 3 or do I need to still specify -d?
Just renew will do. Certbot uses the previous cert to extract the hostnames and the, if that was necessary, now updated renewal configuration file.
It will [try to] renew whichever certs it thinks are still required/being managed by certbot - and in whichever way is defined in the matching renewal config file.
To see what certs are being managed by certbot, you can review the output of:
certbot certificates
