Dear Andy and Seth,
Hope you guys are doing awesome. You’ve helped me earlier in setting up auto-renew for Let’sEncrypt here LetsEncrypt Auto-Renew with Digital Ocean and Server Pilot
I’ve just received an email few days back of Let’sEncrypt certificate expiry and got concerned. So I went on to check my opt/letsencrypt folder.
As you know, I do not know how to handle servers but I had to find my wayout. The crontab is there, so technically it should auto-renew. But I wanted to make sure in case if anything goes wrong then I must be able to take care of it manually.
But today, after logging from root and even serverpilot. I cannot seem to find let’sencrypt folders. I am using Wordpress and iThemes security plugin too. So I tried turning a few settings off to make sure if the folder’s are hidden due to that.
I am clueless and worried about which commands to use to get to that folder to type that renew command. Badly need help before I lose my site!
