Multiple Domains with Same Web root?
EDIT: I'm now rate limited for too many failed attempts :frowning:
My domain is: chukwumaokere.com and chuckokere.com
I ran this command: certbot --apache -d chukwumaokere.com
It produced this output: I cant scroll up far enough in my terminal, but it created successfully. When I try to create the same thing for chuckokere.com, I get this:
"identifier": {
"type": "dns",
"value": "chuckokere.com"
"status": "invalid",
"expires": "2018-07-16T21:37:19Z",
"challenges": [
"type": "http-01",
"error": {
"type": "urn:acme:error:unauthorized",
"detail": "Invalid response from http://chuckokere.com/.well-known/acme-challenge/zSunvP4bpSEosSY0bFyyoDd35FUo12rEt3TZqw6l9sM: "\u003c!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"\u003e\n\u003chtml\u003e\u003chead\u003e\n\u003ctitle\u003e404 Not Found\u003c/title\u003e\n\u003c/head\u003e\u003cbody\u003e\n\u003ch1\u003eNot Found\u003c/h1\u003e\n\u003cp"",
"status": 403
"uri": "https://acme-v01.api.letsencrypt.org/acme/challenge/eFDPXBcYURDi9XXKnBoysj4b_ooK1z7YKioztfY2Jlk/5561563727",
"token": "zSunvP4bpSEosSY0bFyyoDd35FUo12rEt3TZqw6l9sM",
"keyAuthorization": "zSunvP4bpSEosSY0bFyyoDd35FUo12rEt3TZqw6l9sM.e5sgg1DyQNF6Yv9CLAiSk1omPgSKVBl3piZAybretJs",
"validationRecord": [
"url": "http://chuckokere.com/.well-known/acme-challenge/zSunvP4bpSEosSY0bFyyoDd35FUo12rEt3TZqw6l9sM",
"hostname": "chuckokere.com",
"port": "80",
"addressesResolved": [
"162.243.164.52"
"addressUsed": "162.243.164.52"
"type": "dns-01",
"uri": "https://acme-v01.api.letsencrypt.org/acme/challenge/eFDPXBcYURDi9XXKnBoysj4b_ooK1z7YKioztfY2Jlk/5561563728",
"token": "JAmv4LlKo0J_AIf-CASP6yheUV-dsp1eg7UgSkVTIn4"
"combinations": [
0
1
2018-07-09 21:37:26,313:DEBUG:certbot.reporter:Reporting to user: The following errors were reported by the server:
Domain: chuckokere.com
Detail: Invalid response from http://chuckokere.com/.well-known/acme-challenge/zSunvP4bpSEosSY0bFyyoDd35FUo12rEt3TZqw6l9sM: "
404 Not Found
Not Found
<p"
To fix these errors, please make sure that your domain name was entered correctly and the DNS A/AAAA record(s) for that domain contain(s) the right IP address.
2018-07-09 21:37:26,313:DEBUG:certbot.error_handler:Encountered exception:
File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 82, in handle_authorizations
self._respond(aauthzrs, resp, best_effort)
File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 155, in _respond
self._poll_challenges(aauthzrs, chall_update, best_effort)
File "/usr/lib/python3/dist-packages/certbot/auth_handler.py", line 226, in _poll_challenges
raise errors.FailedChallenges(all_failed_achalls)
certbot.errors.FailedChallenges: Failed authorization procedure. chuckokere.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://chuckokere.com/.well-known/acme-challenge/zSunvP4bpSEosSY0bFyyoDd35FUo12rEt3TZqw6l9sM: "
The operating system my web server runs on is (include version): Ubuntu 16.04
My hosting provider, if applicable, is: Domain Host is Godaddy, Server Host is Digital Ocean
Can you please try to create a folder under the domain document root (named .well-known then a folder named acme-challenge under that folder.) After that, please try to create a file (random file) under the acme-challenge & test if that file is accessible from www.
P.S. is there any vHost for chuckokere.com?
Thank you
This test may help identify certain kinds of problems, but I just want to point out that it mirrors what certbot --webroot would do rather than what certbot --apache would do, as certbot --apache doesn't write its test files into an existing directory.
I did as he said (to create the directories and test accessing it)
This file is accessible via the web http://chuckokere.com/.well-known/acme-challenge/testing.txt
the file points to the directory /var/www/html/chukwumaokere/
which is the same web directory as https://chukwumaokere.com
Since they both share the same directory, they’ll share the same directories.
I even tried making /var/www/html/chuckokere/ and changing my .conf file to use that directory. And made that directory a symlink to /var/www/html/chukwumaokere/ which failed
I just tried adding this
<VirtualHost *:443>
ServerName chuckokere.com
ServerAlias www.chuckokere.com
DocumentRoot /var/www/html/chukwumaokere
    <Directory /var/www/html/chukwumaokere>
        AllowOverride All
        Require all granted
    </Directory>
    <IfModule mod_dir.c>
        DirectoryIndex index.php index.pl index.cgi index.html index.xhtml index.htm
    </IfModule>
SSLCertificateFile /etc/letsencrypt/live/chukwumaokere.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/chukwumaokere.com/privkey.pem
to my existing SSL file for chukwumaokere.com
it bypasses the chrome alert when accessing chuckokere.com, and automatically redirects to https, but its understandably crossed out as non valid https
If you want to make use of /var/www/html/chukwumaokere, you could try running Certbot with -a webroot -i apache instead of --apache.
Just tried. It let me specify the webroot but I get this error still:
Failed authorization procedure. chuckokere.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://chuckokere.com/.well-known/acme-challenge/rqE_bTRWAhY1Zs6pSmzdP10V3GUeuK0L7O8_a01F-a8: "
404 Not Found
Not Found
<p", www.chuckokere.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.chuckokere.com/.well-known/acme-challenge/-hzGO4_2A3kRAPMBIQ66KeNAzSTcIJua1Onq6ZcXFXY: " 404 Not Found
Not Found
<p"
I should probably clean up the changes i made to my chukwumaokere.com-le-ssl file and maybe get rid of the symlink for /var/www/html/chuckokere/ -> /var/www/html/chukwumaokere/
first. will try that
Solution worked.
I cleaned up all the extra files i was experimenting with (all the extra lines in my -le-ssl files and symlinks)
just set the vhost file to point to /var/www/html/chukwumaokere
then ran certbot -a webroot -i
followed along, (using /var/www/html/chukwumaokere/ as my webroot) and everythign worked cleanly.
Thanks @schoen
