actually yes I am... as you'd assume there's constant attempts to breach
let me turn that off
oh geez...
You can turn it back on now - LOL
so it was fail2ban
i guess now i need to figure out how to get fail2ban to block the spammers and hackers but not legit auths?
Does the iPhone work now?
yes, both the iPhone and thunderbird sent emails just fine
Thanks!
I'll have to remember this one in case it trigger it again.
If you don't change anything in it - it will happen again.
You're welcome.
I do work for
though...
But I would be just as happy if you would donate a small token, for our time and trouble, to LE.
In any case, cheers from Miami ![]()
you mean if i don't change the fail2ban jail settings?
One of the reasons I run my own "bad IP service" ![]()
Yes, all you did was stop and restart it.
That's not a significant "change" in my book.
the faili2ban jail is set to be 'aggressive'
i'm thinking that when i was testing and setting this up i triggered it (logging in without authenticating a couple times maybe?)
but you're right, at least i know have an immediate quick fix (workaround, if you will) until i can finesse the f2b jail
thx again
My pleasure ![]()
And thanks for the ![]()
