Multi level subdomain certificates
Hello, I am currently trying to setup a certificate on a multi level subdomain of mine, for example:
subdomain1.subdomain2.domain.com, my domain is currently pointing to Cloudflare's name servers and I have setup "subdomain1.subdomain2.domain.com", "subdomain2.domain.com", and "domain.com" to all point to my Debian 12 server's IP address (which are all correctly pointing and working fine). all of the domains are proxied as well
The command I am running to setup Certbot through cloudflare utilizing the associated cloudflare plugin is
certbot -i nginx --dns-cloudflare --dns-cloudflare-credentials ~/.secrets/certbot/cloudflare.ini -d "subdomain1.subdomain2.domain.com" -d "subdomain2.domain.com" -d "domain.com"
Whenever I run this everything seems to work fine as it correctly adds the certificates for both subdomain2.domain.com and domain.com, and I can visit the sites without an issue. but for some reason whenever I visit subdomain1.subdomain2.domain.com it doesn't seem to work giving me a
Secure Connection Failed
An error occurred during a connection to hello.hello.us-central-1-amazonaws.com. Cannot communicate securely with peer: no common encryption algorithm(s).
Error code: SSL_ERROR_NO_CYPHER_OVERLAP
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the website owners to inform them of this problem.
That's a server configuration issue not a cert problem itself.
Still, check that your cert was issued with all 3 names. Use a tool like this to check your apex domain and then check the SANs section for all the names: SSL Checker Or, check using https://crt.sh although it has performed poor recently.
We'd need to know more about the specifics of your server to help with that. It is not in our normal scope but I am sure someone would give advice on it :slight_smile:
Thx for the reply, I went ahead and check and currently it does only show these:
DNS:xx-xxxx-1-xxxxxxxxxxx.com
DNS:*.xx-xxxx-1-xxxxxxxxxxx.com
Total number of SANs: 2
although when I try and run
certbot -i nginx --dns-cloudflare --dns-cloudflare-credentials ~/.secrets/certbot/cloudflare.ini -d "example1.example2.xx-xx-1-xxxxxxxx.com" -v
Plugins selected: Authenticator dns-cloudflare, Installer nginx
Requesting a certificate for example1.example2.xx-xx-1-xxxxxxxx.com
An unexpected error occurred:
AttributeError: can't set attribute
mind you this only happens when trying it for multi level subdomains, if I were to do a singular subdomain or even just the domain it'd work perfectly fine.
Some versions of Certbot gave that error when processing an original error. You may need to update your Certbot.
A cert request for all 3 domains would never produce a cert with just 2 domain names in it. Each Certbot request is a request for a cert. All names must satisfy the challenges or the cert is not issued.
You may be able to find the original error in the Certbot log.
It is very difficult to say much without knowing the actual domain names
Yeah, this. Also:
When you opened this thread in the Help section, you should have been provided with a questionnaire. Maybe you didn't get it somehow (which is weird), or you've decided to delete it. In any case, all the answers to this questionnaire are required:
So this is up to the certificate Cloudflare serves, not the certificate your server has?
Cloudflare usually only gets a cert for example.com and *.example.com -- that doesn't work with sub2.sub1.example.com
There should be a small warning icon about this in your dns records interface on Cloudflare.
Yeah but would you still not be able to serve the certificates through certbot even if proxying your domains through Cloudflare? the entire reason I'm trying to use certbot for this is because of the requirement they have on multi level subdomains (needing to pay).
You should be able to use the certificate you get if you switch proxying off.
I'm not sure if cloudflare gets another cert for the fourth level domain.
Cloudflare Universal SSL will issue certificates only for the apex name and one subdomain.
example.com
*.example.com
If you use deeper subdomains, you will need to either set those hostnames to DNS Only, which bypasses the Cloudflare proxy, or you can add an Advanced Certificate Manager subscription.
On Business Plan, you can upload a custom cert, obtained externally, but that would be annoying because it's manual process (unless you automate with Cloudflare API). It is $200/month, though, so it's definitely more economical to go Advanced Certificate (which is $10/month).
