acme.sh --force --renew -d mail.example.com --server letsencrypt
[root@localhost ~]# acme.sh --force --renew -d mail.example.com.au --server letsencrypt
[Mon Oct 11 10:19:45 AEDT 2021] Renew: 'mail.example.com.au'
[Mon Oct 11 10:19:47 AEDT 2021] Using CA: https://acme-v02.api.letsencrypt.org/directory
[Mon Oct 11 10:19:47 AEDT 2021] Standalone mode.
[Mon Oct 11 10:19:47 AEDT 2021] Multi domain='DNS:mail.example.com.au,DNS:mail.example1.com,DNS:webmail.example1.com,DNS:mail.example3.com,DNS:autodiscover.example1.com,DNS:mail.example2.com.au,DNS:webmail.example2.com.au,DNS:autodiscover.example2.com.au,DNS:webmail.example2.com.au,DNS:mail.cloudflarednsapi.com'
[Mon Oct 11 10:19:47 AEDT 2021] Getting domain auth token for each domain
[Mon Oct 11 10:20:00 AEDT 2021] Getting webroot for domain='mail.example.com.au'
[Mon Oct 11 10:20:00 AEDT 2021] Getting webroot for domain='mail.example1.com'
[Mon Oct 11 10:20:00 AEDT 2021] Getting webroot for domain='webmail.example1.com'
[Mon Oct 11 10:20:01 AEDT 2021] Getting webroot for domain='mail.example3.com'
[Mon Oct 11 10:20:01 AEDT 2021] Getting webroot for domain='autodiscover.example1.com'
[Mon Oct 11 10:20:01 AEDT 2021] Getting webroot for domain='mail.example2.com.au'
[Mon Oct 11 10:20:01 AEDT 2021] Getting webroot for domain='webmail.example2.com.au'
[Mon Oct 11 10:20:01 AEDT 2021] Getting webroot for domain='autodiscover.example2.com.au'
[Mon Oct 11 10:20:01 AEDT 2021] Getting webroot for domain='mail.cloudflarednsapi.com'
[Mon Oct 11 10:20:01 AEDT 2021] mail.example.com.au is already verified, skip dns-01.
[Mon Oct 11 10:20:01 AEDT 2021] mail.example1.com is already verified, skip dns-01.
[Mon Oct 11 10:20:01 AEDT 2021] webmail.example1.com is already verified, skip dns-01.
[Mon Oct 11 10:20:01 AEDT 2021] mail.example3.com is already verified, skip dns-01.
[Mon Oct 11 10:20:01 AEDT 2021] autodiscover.example1.com is already verified, skip dns-01.
[Mon Oct 11 10:20:01 AEDT 2021] mail.example2.com.au is already verified, skip dns-01.
[Mon Oct 11 10:20:02 AEDT 2021] webmail.example2.com.au is already verified, skip dns-01.
[Mon Oct 11 10:20:02 AEDT 2021] autodiscover.example2.com.au is already verified, skip dns-01.
[Mon Oct 11 10:20:02 AEDT 2021] Verifying: mail.cloudflarednsapi.com
[Mon Oct 11 10:20:02 AEDT 2021] Standalone mode server
[Mon Oct 11 10:20:04 AEDT 2021] Pending, The CA is processing your order, please just wait. (1/30)
[Mon Oct 11 10:20:08 AEDT 2021] Pending, The CA is processing your order, please just wait. (2/30)
[Mon Oct 11 10:20:11 AEDT 2021] Pending, The CA is processing your order, please just wait. (3/30)
[Mon Oct 11 10:20:14 AEDT 2021] mail.cloudflarednsapi.com:Verify error:Fetching http://mail.cloudflarednsapi.com/.well-known/acme-challenge/random-string: Timeout during connect (likely firewall problem)
built in (acme.sh)
linux
no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): acme.sh -v 3.0.9
This command used to work it is one single certificate for many domains for a mailhost, a few domains are standalone and one is using cloudflare dns api access, the issue appears that now its trying to renew all domains using standalone mode - I would like to mix this and tell the script to use standalone for X domain and dnsapi for Y domain, it complains about the firewall as that one domain isnt using standalone its using cloudflares DNS api - I have set the CA to LE. Any help would be great !
The certificate is a single one for multiple different domains and all the below domains use the primary domain name (mail.example.com.au) as their MX record, All the domains email is housed on the same hardware.
'mail.example1.com'
'mail.example3.com'
The result of trying curl -v https://acme-v02.api.letsencrypt.org/directory below
[root@localhost ~]# curl -v https://acme-v02.api.letsencrypt.org/directory
- About to connect() to acme-v02.api.letsencrypt.org port 443 (#0)
- Trying 172.65.32.248...
- Connected to acme-v02.api.letsencrypt.org (172.65.32.248) port 443 (#0)
- Initializing NSS with certpath: sql:/etc/pki/nssdb
- CAfile: /etc/pki/tls/certs/ca-bundle.crt
CApath: none - SSL connection using TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
- Server certificate:
- subject: CN=acme-v02.api.letsencrypt.org
- start date: Sep 30 00:25:10 2021 GMT
- expire date: Dec 29 00:25:09 2021 GMT
- common name: acme-v02.api.letsencrypt.org
- issuer: CN=R3,O=Let's Encrypt,C=US
GET /directory HTTP/1.1
User-Agent: curl/7.29.0
Host: acme-v02.api.letsencrypt.org
Accept: /
< HTTP/1.1 200 OK
< Server: nginx
< Date: Sun, 10 Oct 2021 23:16:45 GMT
< Content-Type: application/json
< Content-Length: 658
< Connection: keep-alive
< Cache-Control: public, max-age=0, no-cache
< X-Frame-Options: DENY
< Strict-Transport-Security: max-age=604800
"CczQebFvnWc": "https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/number",
"meta": {
"caaIdentities": [
"letsencrypt.org"
"termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf",
- Connection #0 to host acme-v02.api.letsencrypt.org left intact
