Missing webroot path renewing an existing certificate
root@instance-1:~# certbot certonly \
Error while running apache2ctl configtest.
Action 'configtest' failed.
AH00526: Syntax error on line 35 of /etc/apache2/sites-enabled/000-default-le-ssl.conf:
SSLCertificateFile: file '/etc/letsencrypt/live/casaroca.site/fullchain.pem' does not exist or is empty
1: Apache Web Server plugin (apache) [Misconfigured]
2: Spin up a temporary webserver (standalone)
3: Place files in webroot directory (webroot)
Select the appropriate number [1-3] then [enter] (press 'c' to cancel):
Stop.
Press "C" to cancel that.
There are three commands in my post.
The first two are one line each.
The last command is spread over five lines.
Select the appropriate number [1-3] then [enter] (press 'c' to cancel): cauthenticator could not be determined or is not installedAsk for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details.
Press "ctrl-c"
Break out of that.
what do I do now, i closed
there is no certificate installed from the page,
Follow my instructions.
Three simple commands to run:
error command 3.
NOT
"certbot certonly \"
All five lines at once.
Copy (all five lines) then Paste
--cert-name casaroca.site
-webroot -w /var/www/html
-d "casaroca.org,www.casaroca.org,casaroca.site,www.casaroca.site"
--force-renewal
ebroot does not exist or is not a directory
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /tmp/tmp83elcjk7/log or re-run Certbot with -v for more details.
I missed a dash!
DO THIS COMMAND ONLY ONCE:
certbot certonly \
 --cert-name casaroca.site \
 --webroot -w /var/www/html \
 -d "casaroca.org,www.casaroca.org,casaroca.site,www.casaroca.site" \
 --force-renewal
--force-renewal
Requesting a certificate for casaroca.org and 3 more domains
Domain: casaroca.site
Type: connection
Detail: Fetching http://casaroca.site/.well-known/acme-challenge/eUocwiA2AY669-nraOX2rm869jqrezlcVj2qV0cBZQM: Timeout during connect (likely firewall problem)
Domain: www.casaroca.site
Type: connection
Detail: Fetching http://www.casaroca.site/.well-known/acme-challenge/-x3Mwv2NBgbvNYVjDSLI_D0f26njKe67WGj9vNKRK9o: Timeout during connect (likely firewall problem)
What?
Address: 34.136.223.57
Address: 35.192.111.50
Please show output of:
curl -4 ifconfig.co
root@instance-1:~# curl -4 ifconfig.co
34.136.223.57
the domain casaroca.site, is no longer in operation
It saves time to have the right information...
certbot certonly \
 --cert-name casaroca.org \
 -d "casaroca.org,www.casaroca.org" \
 --force-renewal
Then we need to edit the file:
changing lines with:
/etc/letsencrypt/live/casaroca.site/...
to:
/etc/letsencrypt/live/casaroca.org/...
>  --force-renewal
You are updating certificate casaroca.org to include new domain(s):
  • www.casaroca.org
    You are also removing previously included domain(s):
    (None)
    Did you intend to make this change?
NO.
Don't do that.
Did you skip the first two steps?
Please show the output of:
certbot certificates
