Missing VHOST Entry Means NGINX Plugin Doesn't Work
My domain is:nomjk.com
I ran this command:certbot --nginx as shown on https://certbot.eff.org/#ubuntutyakkety-nginx
It produced this output:success, i guess, but no Live folder created
My web server is (include version):nginx/1.10.3 (Ubuntu)
The operating system my web server runs on is (include version):Ubuntu 17.04
My hosting provider, if applicable, is:self
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
Hi @WMF,
Could you please post your logs from /var/log/letsencrypt? Also, do you have the specific output messages that you saw when running the certbot --nginx command?
AHA! The log states: MisconfigurationError: Cannot find a VirtualHost matching domain nomjk.com. I assume I have to set that up first. I have nomjk.com working on a development machine and should have ported that over first to this box before trying for the cert. But, the output from certbot --nginx was: “Your account credentials have been saved in your Certbot configuration directory at /etc/letsencrypt…” with no mention of any error so yes, I was confused. I will set up nomjk.com on this box, rerun certbot and watch the logs this time. Thanks for your reply.
