While attempting to create a dns-persist-01 challenge on the staging API, I received the following.
"type": "dns-persist-01",
"url": "https://acme-staging-v02.api.letsencrypt.org/acme/chall/281943993/466329203/5pPXaw",
"status": "pending",
"issuer-domain-names": [
"letsencrypt.org"
This seems incorrect.
Section 3.1 Challenge Object of the Internet-Draft clearly specifies (redacted irrelevant parts):
3.1. Challenge Object
The challenge object for "dns-persist-01" contains the following
fields:
* *type* (required, string): ...
* *url* (required, string): ...
* *status* (required, string): ...
* *accounturi* (required, string): A URI identifying the ACME
account requesting validation, using the identifier format
specified in [RFC8657], Section 3. This is the URI the CA expects
in the DNS record and the mechanism by which the CA communicates
alternative URIs to the client. Clients that pre-provisioned a
record using their ACME account URL ([RFC8555], Section 7.3)
SHOULD verify the value identifies the same account.
Yet the challenge I received from LE doesn't have it.
