Hello All,
I am running the Certbot on my fresh installed Centos 8 by following the instruction - https://certbot.eff.org/lets-encrypt/centosrhel8-apache
But I got the below error:
[root@web ~]# /usr/local/bin/certbot-auto --apache
Error while running apachectl configtest.
AH00526: Syntax error on line 85 of /etc/httpd/conf.d/ssl.conf:
SSLCertificateFile: file '/etc/pki/tls/certs/localhost.crt' does not exist or is empty
The apache plugin is not working; there may be problems with your existing configuration.
The error was: MisconfigurationError("Error while running apachectl configtest.\n\nAH00526: Syntax error on line 85 of /etc/httpd/conf.d/ssl.conf:\nSSLCertificateFile: file '/etc/pki/tls/certs/localhost.crt' does not exist or is empty\n",)
[root@web ~]#
Before running the certbot, I have only added a new virtual host config file under /etc/httpd/conf.d/, all others leaves in default.
Please advise how to get the certfile /etc/pki/tls/certs/localhost.crt ?
Thanks.
