karlaporter.com
certbot certonly -a webroot --expand --webroot-path=/home/kp -d karlaporter.com -d www.karlaporter.com
Installed certbox
Nginx 1.14.1
CentOS 8
Digital Ocean
Yes
NO
or certbot-auto --version
if you're using Certbot):
1.10.1
I love LE and have used it to install certbot in my previous liux box (centos 7). Now we've upgraded to a CentOS 8 box. All our domains have moved over with a simple rsync, including the /etc/letsencrypt
folders, and the /etc/security/
where we had generated the SSL stuff.
Question: is this a good enough way to "move" the certs, or will we have to regenerate the certs on this new server all afresh? Whenn I issue certbot -renew
it gives me errors. Hence the question.
Thanks!
