My domain is: www.sjippertjes.nl & test.sjippertjes.nl
My web server is (include version): Apache 2.4.46
We'd need a lot more info than just "Migrate problem(s)"
But, a quick check of your domain shows it cannot be reached using HTTP or HTTPS. Many things can cause that but it is not related to any previous certificate.
Check things like the IP in the DNS, firewall settings, web server configuration, router setings (if any), and any other comms related setup. If you are using a hosting company consult with their tech support too.
Once connectivity is working if you have trouble with the certificate let us know and we can help
In short I was migrating Apache 2.4.46 from an 15 yrs old windows 10 machine (8GB RAM,i3-4th gen, 3.6 TB HDD). And also Letsencrypt by Certbot.
New machine: Windows server 2025 Datacenter (24H2) on a HP Prodesk 600 G5 SFF, 16 GB RAM, i5-9th gen., 1 TB M2.5 SSD, 4 GB HDD.
The problem proved to be the symbolc links that would not be copied in (and out) a zip-file. Finally 7Zip did it well.
If you're using Windows server, there are almost certainly better choices than Certbot available. Certbot was only available for Windows for a limited time in beta, and they ended up deciding that it wasn't worth supporting. I'd recommend using simple-acme instead, especially since the versions of Certbot that were released for Windows I don't think check ARI or handle well the coming shorter-duration certificates.
