Or just call it a day and use another ACME client that can.
Does this look right?
# openssl verify -verbose -show_chain -CAfile /etc/letsencrypt/live/algasol.com/chain.pem /etc/letsencrypt/live/algasol.com/cert.pem
/etc/letsencrypt/live/algasol.com/cert.pem: OK
Chain:
depth=0: CN = *.algasol.com (untrusted)
depth=1: C = US, O = Let's Encrypt, CN = R3
depth=2: C = US, O = Internet Security Research Group, CN = ISRG Root X1
This is the command I ran (after some confusion and work trying to figure out exactly what string to pass to the --preferred-chain parameter):
docker run -it --rm --name certbot \ -v "/root/.linode_api:/root/.linode_api" \ -v "/etc/letsencrypt:/etc/letsencrypt" \ -v "/var/lib/letsencrypt:/var/lib/letsencrypt" \ -v "/var/log:/var/log" \ -v "/etc/letsencrypt/renewal-hooks/deploy" \ certbot/dns-linode renew --force-renewal --preferred-chain "ISRG Root X1"
But I'm still getting a broken chain diagnostic from "SSL Checker" after having deployed via the virtualmin install-cert command and restarting apache
That's because the webserver for algasol.com is still only serving the leaf certificate (and no intermediate certificates):
https://decoder.link/sslchecker/algasol.com/443
You need to fix your Apache configuration to actually serve the intermediate certificates.
OK, I went in and manually over-rode the virtualmin install-cert operation in the apache2 configuration for algasol.com:
#SSLCACertificateFile /home/algasol/ssl.ca
SSLCACertificateFile /etc/letsencrypt/live/algasol.com/chain.pem
So web access works now.
I'll have to do the same for dovecot etc. as well apparently.
Looking better. I'm not seeing the second intermediate certificate (ISRG Root X1) though, probably because of this:
It all depends upon which chain you want:
IPv4 and IPv6 are not identical:
openssl s_client -connect algasol.com:443 -servername algasol.com -4 | head
verify return:1
depth=1 C = US, O = Let's Encrypt, CN = R3
verify return:1
depth=0 CN = *.algasol.com
verify return:1
CONNECTED(00000005)
Certificate chain
0 s:CN = *.algasol.com
openssl s_client -connect algasol.com:443 -servername algasol.com -6 | head
140715871445440:error:1408F10B:SSL routines:ssl3_get_record:wrong version number:../ssl/record/ssl3_record.c:332:
CONNECTED(00000005)
no peer certificate available
SSL handshake has read 5 bytes and written 313 bytes
Verification: OK
IPv6 fails
That's a great observation @rg305. I suspect that this may further indicate Apache configuration issues. Maybe incorrectly using IP:80 in the VirtualHosts instead of *:80 ?
