Manual Renewal Failing
www.lsl-technology.com lsl-technology.com
certbot certonly --manual -d www.lsl-technology.com -d lsl-technology.com
After running the command, I am asked to add the following two txt files with specific content into the files.
Create a file containing just this data:
NIICyQ7K9YLp30qTv54t4vutEXvAmdH_N6ZCAPTnqs0.eiCJBvGKYtMMWMbTeSxmSokVGx8V4tax-GWK-xF9CKA
http://lsl-technology.com/.well-known/acme-challenge/NIICyQ7K9YLp30qTv54t4vutEXvAmdH_N6ZCAPTnqs0
Press Enter to Continue
Yxrc3eT0CF0XjgAXCaxc30BUFhp6aXkrLh7p1tifMEM.eiCJBvGKYtMMWMbTeSxmSokVGx8V4tax-GWK-xF9CKA
http://www.lsl-technology.com/.well-known/acme-challenge/Yxrc3eT0CF0XjgAXCaxc30BUFhp6aXkrLh7p1tifMEM
(This must be set up in addition to the previous challenges; do not remove,
replace, or undo the previous challenge tasks yet.)
Domain: lsl-technology.com
Detail: 2a05:d01c:4c2:c600:fc34:498e:2999:d536: Invalid response from http://lsl-technology.com/.well-known/acme-challenge/NIICyQ7K9YLp30qTv54t4vutEXvAmdH_N6ZCAPTnqs0: 404
Domain: www.lsl-technology.com
Detail: 2a05:d01c:4c2:c600:fc34:498e:2999:d536: Invalid response from http://www.lsl-technology.com/.well-known/acme-challenge/Yxrc3eT0CF0XjgAXCaxc30BUFhp6aXkrLh7p1tifMEM: 404
Hint: The Certificate Authority failed to verify the manually created challenge files. Ensure that you created these in the correct location.
Ever though the files are present in the relevant directory.
lsb_release -a
LSB Version: core-11.1.0ubuntu4-noarch:security-11.1.0ubuntu4-noarch
Distributor ID: Ubuntu
Description: Ubuntu 22.04.4 LTS
Release: 22.04
Codename: jammy
YES
NO
certbot 1.21.0
I started off trying to do a manual renewal, that failed with challenge issues, I then tried the manual creation and that failed.
I then deleted the certificates and tried to install them from the start and also get the same error.
The DNS points to my server and the site is up and running.
I have also tried reading loads of posts and cannot seem to figure out what is causing the issue.
Could it be that I still have acme records within the DNS config. Should these be removed before trying the installation of the certificates.
Thanks for your help and guidance.
Lawrence
Have you verified the IPv6 address too?
With IPv4 your server is: Server: nginx
With IPv6 your server is: server: LiteSpeed
@bruncsak
How do I do that?
Thanks
Lawrence
Execute the following command on the server:
ip -6 address show scope global | awk '/inet6/ {print $2}'
Compare the output of the command with the IPv6 address of the domain lsl-technology.com, [2a05:d01c:4c2:c600:fc34:498e:2999:d536] advertised in the DNS.
running ip a on the dunnsland server I see the following,
inet6 2001:41d0:800:100e::/56 scope global
inet6 fe80::ae1f:6bff:fe1b:94e4/64 scope link
This does not seem anywhere near the same as what you say DNS is presenting.
How can I resolve this?
Thanks
Lawrence
Just change the IPv6 address of the names lsl-technology.com and www.lsl-technology.com from 2a05:d01c:4c2:c600:fc34:498e:2999:d536 to 2001:41d0:800:100e:: in the DNS.
Please note that this is basic networking and absolutely not the scope of this Community. A basic understanding of server/network operations is assumed and, if I may say so, a prerequisite for even considering running a webserver.
Also, is there a specific reason why you're using the --manual plugin with the http-01 challenge? The --manual plugin is difficult to automate and other options such as the --webroot plugin are usually a way better choice.
I do have a good understanding of how things work, I am only lost and don't understand why I am seeing issues when trying to register certificates on my domain. I don't understand how my ipv6 address is different from my DNS and my server, that makes no sense.
The reason I was trying the manual route is because the basic route also failed but the failure was saying that the response was not what was expected. I assumed that it could not read the txt file that I placed on the server. The errors provided say nothing about ipv6. It only says that the expected response was not correct.
How can I get more clear accurate logging for what is really causing teh conflict?
Lawrence
That's because Let's Encrypt cannot know if the IP(v6) address is correct or not. It cannot tell you more than it knows, it doesn't have a crystal ball.
It does provide however the IP address used, so one can match that to the expected IP address of the host. I.e.: some basic deduction and investigation is necessary by a human.
I'd like to suggest to revert to the non-manual route after fixing the DNS/IPv6 address issue, as the manual plugin should only be used as a last resort when the other authenticators are not possible.
You can't. You manually need to investigate the DNS settings for your domain name and try to figure out why it doesn't use the IP(v6) address of the server and fix it.
