My domain is: landproject.davidjpeacock.dev
I ran this command: sudo certbot renew
Processing /etc/letsencrypt/renewal/landproject.davidjpeacock.dev.conf
Could not choose appropriate plugin: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError(‘An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.’,)
Attempting to renew cert (landproject.davidjpeacock.dev) from /etc/letsencrypt/renewal/landproject.davidjpeacock.dev.conf produced an unexpected error: The manual plugin is not working; there may be problems with your existing configuration.
The error was: PluginError(‘An authentication script must be provided with --manual-auth-hook when using the manual plugin non-interactively.’,). Skipping.
/etc/letsencrypt/live/landproject.davidjpeacock.dev/fullchain.pem (failure)
N/A; this certificate is targeted for a GitLab Pages website.
N/A; this certificate is targeted for a GitLab Pages site.
GitLab Pages
no
no
certbot 0.23.0
