HiI am using certbot with Apache on Ubuntu. It works well, However I am not using standard SSL port.
So each time I run the script I have to open the 443 port.
I have try to specific a port with certbot with success. I presusme it likes with my Apache configuration but I am stuck (Apache is listening 443, but My firewall is forwarding my custom port on the web to the 443 internal)
Thanks for your help. Here is certbot messages if it can help.
sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/WHATEVER.net.conf
tls-sni-01 challenge for jeedom.baviere.net
Waiting for verification…
Attempting to renew cert (WHATEVER.net) from /etc/letsencrypt/renewal/WHATEVER.net.conf produced an unexpected error: Failed authorization procedure. WHATEVER.net (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Timeout. Skipping.
/etc/letsencrypt/live/WHATEVER.net/fullchain.pem (failure)
