Lockpad not working on old mobile phones
Dear friends,
help me please,
I am owner of website (blog) https://sasamilivojev.com
www.sasamilivojev.com
People can’t open website on older mobile phone devices, they are getting notification that “website is not secure”, but website have valid SSL certificate issued automatically by Let’s encrypt, and lockpad working on new devices and windows computer. Lockpad not working for example on old Samsung phone A8.
I am informed by Domain provider that only you can fix it. Need to add TLS ver.1.2, and maybe to disable ver.1? What you can do?
Please help, its very important.
Best regards,
Hi @sasamilivojev , and welcome to the LE community forum :slight_smile:
Please fill out this form (you have already supplied some of the information, thank you):
@sasamilivojev, here results from
SSL Labs SSL Server Test
https://tls.imirhil.fr/https/www.sasamilivojev.com
For sasamilivojev.com:
DNS Lookup - Check DNS Records
For www.sasamilivojev.com:
I strongly suggest using ONLY TLS v1.3 and v1.2
look here for assistance on initial configuration Mozilla SSL Configuration Generator
Thank you, but I don’t understand this. I just can see that my website not working on older mobile phones, “not secure”. I am using Plesk. What I can do? How to add tls ver.1.3 ? Or Lets Encrypt will fix this?
Help please
The LOCK isn't working on anything; The certificate expired more than one year ago!
Please use:
with www.sasamilivojev.com as the hostname
and look for this section when it is done
And @sasamilivojev,
As far as I can tell the LE Certificate is in place, not expired, and look fine.
Mozilla SSL Configiguration Generator can help you with that.
But I don’t understand this. How to generate and where to add code?
Not expired
The confusion is that that site is handing out TWO certs.
One is active, one is expired.
Server: Microsoft-IIS/8.5
Do you know your way around in IIS?
That is a problem! @sasamilivojev you need have your site only hand out the ONE non-expired certificate.
Remove the expired certificate.
I do not, so I'll leave you in the very capable hands of @rg305
Thank You, I think that you are right. One is expired ZeRo SSL which I added before, but after - domain provider installed Lets encrypt for me, and now I am getting new certificate automatically after 90 days.
So what I can do? To delete all old certificates in Plesk?
Lockpad working on Windows computer and Iphone, not wotking on old Samsung A8 for example.
I am new here, and I don’t understand tls, expiriance: Zero. I only can see that my website not working on old mobile phones and looking for help how to fix. Technical support of domain and hosting provider don’t care for my problem
Sorry, I don't know Plesk.
Maybe you can ask your provider for help ? ? ?
Thank you. So what I can do now? In Plesk to remove expired certificates and use only Automatic Let’s encrypt? Than website will work on older mobile phones?
I don't yet know why the old phones are failing, so I can't be certain.
But it is something you need to do [remove the expired cert].
Provider don’t care. They told me to ask for help Internet Engineering Task Force (IETF), but IETF replied to me to ask for help here at community.letsencrypt.org
