Limit not reached, but have a error
I can't say that I disagree there. :upside_down_face: I'm not a fan of some of snap's issues. Unfortunately, it is the "official" way to install certbot.
WAS: unknown, server reinstalled
NOW:
root@blog:/etc/nginx/sites-available# nginx -t
root@blog:/etc/nginx/sites-available# nginx -T
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
        worker_connections 768;
        # multi_accept on;
http {
        # Basic Settings
        sendfile on;
        tcp_nopush on;
        types_hash_max_size 2048;
        # server_tokens off;
        # SSL Settings
        ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
        ssl_prefer_server_ciphers on;
        # Logging Settings
        # Gzip Settings
        gzip on;
        # gzip_vary on;
        # gzip_proxied any;
        # gzip_comp_level 6;
        # gzip_buffers 16 8k;
        # gzip_http_version 1.1;
        # Virtual Host Configs
#mail {
#       # See sample authentication script at:
#       # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
#       # auth_http localhost/auth.php;
#       # pop3_capabilities "TOP" "USER";
#       # imap_capabilities "IMAP4rev1" "UIDPLUS";
#       server {
#               listen     localhost:110;
#               protocol   pop3;
#               proxy      on;
#       server {
#               listen     localhost:143;
#               protocol   imap;
#               proxy      on;
# configuration file /etc/nginx/modules-enabled/50-mod-http-geoip.conf:
load_module modules/ngx_http_geoip_module.so;
# configuration file /etc/nginx/modules-enabled/70-mod-stream-geoip.conf:
load_module modules/ngx_stream_geoip_module.so;
(removed due too long)
# configuration file /etc/nginx/sites-enabled/00-default:
        listen 80 default_server;
        root /var/www/00-default;
        server_name _;
                try_files $uri $uri/ =404;
# configuration file /etc/nginx/sites-enabled/blog.wintersky.ru:
        listen [::]:80;
        root /var/www/blog;
        server_name blog.wintersky.ru;
Please edit your post and add 3 backticks above and below the output, like this:
output
Otherwise our platform mangles your output.
I can't build it from source?
As a red-eyed-kid, who lived on Gentoo, I am not afraid of the command 'make' :wink:
You'd probably get along well with @Osiris here. :grin:
user www-data;
pid /run/nginx.pid;
events {
        # multi_accept on;
http {
        # Basic Settings
        sendfile on;
        tcp_nopush on;
        # SSL Settings
        # Logging Settings
        # Gzip Settings
        gzip on;
        # gzip_vary on;
        # gzip_proxied any;
#mail {
#       server {
#               protocol   pop3;
#               proxy      on;
#       server {
#               protocol   imap;
#               proxy      on;
types {
    text/html                             html htm shtml;
    text/css                              css;
    text/xml                              xml;
    image/gif                             gif;
    image/jpeg                            jpeg jpg;
    application/javascript                js;
    application/atom+xml                  atom;
    application/rss+xml                   rss;
    text/mathml                           mml;
    text/plain                            txt;
    text/vnd.sun.j2me.app-descriptor      jad;
    text/vnd.wap.wml                      wml;
    text/x-component                      htc;
    image/png                             png;
    image/tiff                            tif tiff;
    image/vnd.wap.wbmp                    wbmp;
    image/x-icon                          ico;
    image/x-jng                           jng;
    image/x-ms-bmp                        bmp;
    image/svg+xml                         svg svgz;
    image/webp                            webp;
    application/font-woff                 woff;
    application/java-archive              jar war ear;
    application/json                      json;
    application/mac-binhex40              hqx;
    application/msword                    doc;
    application/pdf                       pdf;
    application/postscript                ps eps ai;
    application/rtf                       rtf;
    application/vnd.apple.mpegurl         m3u8;
    application/vnd.ms-excel              xls;
    application/vnd.ms-fontobject         eot;
    application/vnd.ms-powerpoint         ppt;
    application/vnd.wap.wmlc              wmlc;
    application/vnd.google-earth.kml+xml  kml;
    application/vnd.google-earth.kmz      kmz;
    application/x-7z-compressed           7z;
    application/x-cocoa                   cco;
    application/x-java-archive-diff       jardiff;
    application/x-java-jnlp-file          jnlp;
    application/x-makeself                run;
    application/x-perl                    pl pm;
    application/x-pilot                   prc pdb;
    application/x-rar-compressed          rar;
    application/x-redhat-package-manager  rpm;
    application/x-sea                     sea;
    application/x-shockwave-flash         swf;
    application/x-stuffit                 sit;
    application/x-tcl                     tcl tk;
    application/x-x509-ca-cert            der pem crt;
    application/x-xpinstall               xpi;
    application/xhtml+xml                 xhtml;
    application/xspf+xml                  xspf;
    application/zip                       zip;
    application/octet-stream              bin exe dll;
    application/octet-stream              deb;
    application/octet-stream              dmg;
    application/octet-stream              iso img;
    application/octet-stream              msi msp msm;
    application/vnd.openxmlformats-officedocument.wordprocessingml.document    docx;
    application/vnd.openxmlformats-officedocument.spreadsheetml.sheet          xlsx;
    application/vnd.openxmlformats-officedocument.presentationml.presentation  pptx;
    audio/midi                            mid midi kar;
    audio/mpeg                            mp3;
    audio/ogg                             ogg;
    audio/x-m4a                           m4a;
    audio/x-realaudio                     ra;
    video/3gpp                            3gpp 3gp;
    video/mp2t                            ts;
    video/mp4                             mp4;
    video/mpeg                            mpeg mpg;
    video/quicktime                       mov;
    video/webm                            webm;
    video/x-flv                           flv;
    video/x-m4v                           m4v;
    video/x-mng                           mng;
    video/x-ms-asf                        asx asf;
    video/x-ms-wmv                        wmv;
    video/x-msvideo                       avi;
        server_name _;
        listen [::]:80;
        root /var/www/blog;
Only IPv6?
Otherwise you need this too:
listen 80;
Do you want to?
https://hub.docker.com/r/certbot/certbot/
It's risky, you must remember to use your volumes correctly.
If that's too much you can try acme.sh
You can install it via pip.
sorry, mistype after uninstalling 'staging env' of certbot. Of couse, there must be 'listen 80;'
Try running this:
certbot certonly --nginx -d "blog.wintersky.ru" --dry-run
Of course, now all is correct:
root@blog:/etc/nginx/sites-available# certbot certonly --nginx -d "blog.wintersky.ru" --dry-run
Simulating a certificate request for blog.wintersky.ru
http-01 challenge for blog.wintersky.ru
 - The dry run was successful.
You might need to run this first:
nginx -s reload
Of course I did it :slight_smile: (after fixing configs with listen 80)
I don't think --dry-run actually tries to install the certificate, I'm not sure but there's a possibility it only checks the issuing pipeline.
You can add extra.wintersky.ru A record to your DNS with same address as blog.wintersky.ru then add extra.wintersky.ru to your server_name directive then run nginx -s reload then:
certbot --nginx -d "blog.wintersky.ru,extra.wintersky.ru"
You are correct @9peppe. :slightly_smiling_face: It does not "dry run" the install.
What I gave you will get you through the week then you can issue the correct certificate (without extra) and run this to safely delete the unneeded certificate:
certbot delete --cert-name NAME
where NAME comes from:
certbot certificates
Make certain that your nginx configuration is not pointing to a certificate that you delete or your nginx will choke.
lifehack ?
trying to do this...
It's a bit of work, but it works.
