ak31
May 22, 2018, 3:44am
1
Having an issue renewing free cert. I have listed concise information below but getting errors when trying to run letsencrypt commands and its been awhile since I have set this up.
OS: Ubuntu 16
Sever:Guacamole w/ NGINX Settings
*******************Letsencrypt error message
guacadmin@GuacSecondary:~$ sudo letsencrypt renew
Processing /etc/letsencrypt/renewal/addmoreroutes.com.conf
2018-05-21 23:34:30,044:WARNING:letsencrypt.cli:Attempting to renew cert from /etc/letsencrypt/renewal/addmoreroutes.com.conf produced an unexpected error: Failed authorization procedure. addmoreroutes.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://addmoreroutes.com/.well-known/acme-challenge/xxxxxxxI: Error getting validation data. Skipping.
/etc/letsencrypt/live/addmoreroutes.com/fullchain.pem (failure)
Domain: addmoreroutes.com
Type: connection
Detail: Fetching http://addmoreroutes.com/.xxxxxx Error
that you are serving files from the webroot path you provided
*******************LetsEncrypt Debug Errors
ANotWorking
ERROR
addmoreroutes.com has an A (IPv4) record (x.x.x.x) but a request to this address over port 80 did not succeed.
Get http://addmoreroutes.com/.well-known/acme-challenge/letsdebug-test: failed to parse Location header "https://\addmoreroutes.com\/.well-known/acme-challenge/letsdebug-test": parse https://\addmoreroutes.com/.well-known/acme-challenge/letsdebug-test: invalid character "\" in host name
Trace:
Making a request to http://addmoreroutes.com/.well-known/acme-challenge/letsdebug-test (using initial IP 50.89.182.245)
Dialing 50.89.182.245
*********************Nginx Settings
guacadmin@GuacSecondary:~$ sudo nano /etc/nginx/nginx.conf
user www-data;
worker_processes 4;
pid /run/nginx.pid;
events
worker_connections 768;
http
# My Certificates
ssl_certificate /etc/nginx/ssl/addmoreroutes.com/fullchain.pem;
ssl_certificate_key /etc/nginx/ssl/addmoreroutes.com/privkey.pem;
# SSL Performance Related
ssl_session_cache shared:SSL:10m;
ssl_session_timeout 10m;
# SSL Protocols and Ciphers
ssl_prefer_server_ciphers on;
ssl_protocols TLSv1.2;
ssl_ciphers "ECDH+AESGCM:DH+AESGCM:ECDH+AES256:DH+AES256:!AES128:!aNULL:!MD5:!eNULL:!EXPORT:!DES:!PSK:!RC4";
# DHE Key-Exchange
ssl_dhparam /etc/nginx/ssl/addmoreroutes.com/dhparam.pem;
# Random Security Stuff
server_tokens off;
add_header X-Frame-Options DENY;
add_header X-Content-Type-Options nosniff;
add_header X-XSS-Protection "1; mode=block";
add_header Strict-Transport-Security max-age=63072000;
# Common Proxy Settings
proxy_set_header Host \$host;
proxy_set_header X-Real-IP \$remote_addr;
proxy_set_header X-Forwarded-For \$proxy_add_x_forwarded_for;
# Default Config Stuff #
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 4096; #Default:2048
gzip on;
gzip_disable "msie6";
# REDIRECTS ALL PORT 80/HTTP to 443/HTTPS
server
listen 80;
listen [::]:80;
server_name addmoreroutes.com;
location ~ /.well-known/acme-challenge
root /var/www/html/;
return 301 https://$host/$request_uri;
# GUACAMOLE SERVER SETTINGS
server
listen 443 ssl;
listen [::]:443 ssl;
proxy_buffering off;
proxy_redirect off;
proxy_cookie_path /guacamole/ /;
proxy_http_version 1.1;
proxy_set_header Upgrade \$http_upgrade;
proxy_set_header Connection "upgrade";
location /
proxy_pass http://x.x.x.x:8080/guacamole/;
_az
May 22, 2018, 3:47am
2
The server is sending a malformed redirect: Let's Debug
$ curl -X GET -I addmoreroutes.com/.well-known/acme-challenge/xxx
Server: nginx
Date: Tue, 22 May 2018 03:47:00 GMT
Content-Type: text/html
Content-Length: 178
Location: https://\addmoreroutes.com\/.well-known/acme-challenge/xxx
X-Frame-Options: DENY
X-Content-Type-Options: nosniff
X-XSS-Protection: 1; mode=block
Strict-Transport-Security: max-age=63072000
I think this is it:
What is this backslash? That is not necessary in nginx configs and explains why the proxied application might think the Host header begins with a backslash.
rg305
May 22, 2018, 3:49am
4
This location may need a "try" in it.
ak31
May 22, 2018, 3:50am
5
which one I have it listed for both http and https
rg305
May 22, 2018, 3:51am
6
in both, but the challenge is going to HTTP:
The challenge requests are being redirected and garbled.
wget http://addmoreroutes.com/.well-known/acme-challenge/test.txt
--2018-05-21 23:50:41-- http://addmoreroutes.com/.well-known/acme-challenge/test.txt
Resolving addmoreroutes.com (addmoreroutes.com)... 50.89.182.245
Connecting to addmoreroutes.com (addmoreroutes.com)|50.89.182.245|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: https://\addmoreroutes.com\/.well-known/acme-challenge/test.txt [following]
--2018-05-21 23:50:41-- https://%5Caddmoreroutes.com%5C/.well-known/acme-challenge/test.txt
Resolving \\addmoreroutes.com\\ (\\addmoreroutes.com\\)... 50.89.182.245
Connecting to \addmoreroutes.com\ (\addmoreroutes.com\)|50.89.182.245|:443... connected.
ERROR: cannot verify \\addmoreroutes.com\\'s certificate, issued by ‘CN=Let's Encrypt Authority X3,O=Let's Encrypt,C=US’:
Issued certificate has expired.
ERROR: no certificate subject alternative name matches
requested host name ‘\\addmoreroutes.com\\’.
To connect to \\addmoreroutes.com\\ insecurely, use `--no-check-certificate'.
ak31
May 22, 2018, 3:53am
7
what would be the syntax to add the try statement ?
_az
8
If you want to avoid the HTTPS redirect, you’ll need to put the return 301 into a location / { } block, otherwise it will override the acme-challenge location block.
Still, you should instead fix the weird backslash, as it will affect all of your visitors.
ak31
May 22, 2018, 3:54am
9
how would I add the try statement in here
rg305
10
something like:
try_files $uri 404;
ak31
May 22, 2018, 3:55am
11
like this
try_files $uri 404;
rg305
May 22, 2018, 3:57am
12
Sorry:
try_files $uri =404;
But basically yes.
rg305
May 22, 2018, 3:58am
13
And that black slash seems problematic.
Actually all of these too:
ak31
May 22, 2018, 4:00am
14
Corrected the proxy set header statements by removing the backslash and added the try statements and retested and still same error
***********New Output
user www-data;
worker_processes 4;
pid /run/nginx.pid;
events
http
# My Certificates
# DHE Key-Exchange
server_tokens off;
proxy_set_header Host $host;
sendfile on;
tcp_nopush on;
tcp_nodelay on;
gzip on;
server
listen 80;
listen [::]:80;
server
listen 443 ssl;
proxy_redirect off;
location /
proxy_pass http://x.x.x.x/guacamole/;
rg305
May 22, 2018, 4:02am
15
restart web service
service nginx restart
ak31
May 22, 2018, 4:03am
16
Your the Man
Effing Props
rg305
May 22, 2018, 4:05am
17
Not sure, but as @_az pointed out, that redirect may need to be inside a location; like:
location /
rg305
May 22, 2018, 4:10am
19
two separate locations:
location /
So that it is more like:
When location A, do this.
When location B, do this.
rg305
May 22, 2018, 4:15am
21
Only in the port 80 block; not the 443 block.
((You don't need to redirect to https within the https block - LOL))
Leave 443 as before:
