My domain is: test.planetbeyondapps.com
I ran this command: certbot renew --cert-name test.pla.com -v
Processing /etc/letsencrypt/renewal/test.pla.com.conf
The following certificates are not due for renewal yet:
/etc/letsencrypt/live/test.pla.com/fullchain.pem expires on 2024-10-22 (skipped)
No renewals were attempted.
[root@nginx-rh8-dmz-235 ~]# certbot renew --cert-name test.pla.com -v
Certificate is due for renewal, auto-renewing...
Renewing an existing certificate for test.pla.com
http-01 challenge for test.pla.com
Challenge failed for domain test.pla.com
Domain: test.pla.com
Detail: 117.20.23.229: Invalid response from https://test.pla.com/.well-known/acme-challenge/G-EF_WuwuxdhVvl_qXVTJFS7nuTW2WhR-jfQop1naf0: 404
Failed to renew certificate test.pla.com with error: Some challenges have failed.
/etc/letsencrypt/live/test.pla.com/fullchain.pem (failure)
My web server is (include version): Nginx version 1.22.0. Compiled from source.
The operating system my web server runs on is (include version): Red Hat Enterprise Linux release 8.9 (Ootpa)
My hosting provider, if applicable, is: NA
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.22.0
My domain config is as below
cat /etc/nginx/conf.d/test.pla.com.conf
server_name test.pla.com;
access_log /var/log/nginx/test.pla.com.access.log main;
include include/error.conf;
###### For LEtsencrypt Certificates ########
location /.well-known/acme-challenge {
alias /var/www/html/.well-known/acme-challenge;
try_files $uri =404;
default_type text/plain; # Ensure files are served as plain text
proxy_pass http://192.168.0.244:9001/;
include include/proxy.conf;
It think that challenge files is not being written on /var/www/html/.well-known/acme-challenge/ or may be any thing else. Because when i run the certbot renew --cert-name demo.highersummit.com it did not create any file in acme-challenge directory as monitored by below command.
watch -n 1 ls -lh /var/www/html/.well-known/acme-challenge/
Also check no permission issue. directory is with 755 and nginx:nginx ownership. Verified from below command.
sudo -u nginx touch /var/www/html/.well-known/acme-challenge/testfile
echo "test-acme" | sudo tee /var/www/html/.well-known/acme-challenge/testfile
I am able to access it browser with the required URL
https://demo.highersummit.com/.well-known/acme-challenge/testfile (accessible - can be verified)
Even i manually place the file mentioned in the error "G-EF_WuwuxdhVvl_qXVTJFS7nuTW2WhR-jfQop1naf0" can be accessible on https://demo.highersummit.com/.well-known/acme-challenge/G-EF_WuwuxdhVvl_qXVTJFS7nuTW2WhR-jfQop1naf0.
Dont know why letsencrypt is unbale to validating the challenge for my domain. I have multiple domains and facing same issue.
Please looking for support. Thank you.
