Letsencrypt is trying to validate my domain using an outdated IP address
I have moved my application hosted in AWS from a traditional VM host to a new VM with a Docker containerized architecture. Because of that the IP address associated to the domain names listed below were changed from the previous VM to the new VM.
In my old traditional host I’ve used certbot to generate a letsencrypt certificate for the domains which are not working now when they were associated to the previous IP address.
My new Docker architecture uses a Traefik proxy container to handle access to the other exposed containers behind it. It also manages letsencrypt certificates on the fly.
In order to setup and test the new architecture before redirecting my production domain names to the new IP address, I have defined an additional domain name to the new VM, which access the same docker container as the migrated domain names and that was working before and keeps working now after migration.
After migration, Traefik is able to generate letsencrypt certificates for the domain names that were already associated to the new IP address but isn’t able to do the same for the ones that had the IP address changed, apparently because letsencrypt is trying to validate the domain names using the previous IP address. In this later case, Traefik generates self signed certificates which are naturally identified by web browsers as a potential threat.
In order to stop letsencrypt from using the old IP address to validate the domain names must I need to revoke the old certificates generated using certbot?
My domains are:
Not working, IP address has changed:
checkupinteligente.com.br
www.checkupinteligente.com.br
Working, IP address hasn’t changed:
prod.checkupinteligente.com
prod.checkupinteligente.com.br
Traefik handles letsencrypt certificates.
This is Traefik’s log message regarding the issue:
“Invalid response from https://checkupinteligente.com/ [52.67.50.125]:”
Where 52.67.50.125 is the old IP address for the not working domain names.
Server version: Apache/2.4.38 (Debian)
Server built: 2019-08-18T13:34:20
I’m using the following Docker images:
traefik:latest, running Alpine Linux v3.10
php:7.3-apache, running Debian GNU/Linux 10 (buster) (used for the web server associated to the working and not working domains above)
AWS with a VM instance provisioned using docker-machine.
Yes, but through Docker.
No.
Hi @alexluna
checking these both domain names
via https://check-your-website.server-daten.de/?q=checkupinteligente.com and https://check-your-website.server-daten.de/?q=prod.checkupinteligente.com there is the same ip address:
checkupinteligente.com A 18.228.24.153 São Paulo/Brazil (BR) - Amazon Technologies Inc. Hostname: ec2-18-228-24-153.sa-east-1.compute.amazonaws.com yes 2 0
AAAA yes
www.checkupinteligente.com C checkupinteligente.com yes 1 0
prod.checkupinteligente.com A 18.228.24.153 São Paulo/Brazil (BR) - Amazon Technologies Inc. Hostname: ec2-18-228-24-153.sa-east-1.compute.amazonaws.com yes 1 0
AAAA yes
www.prod.checkupinteligente.com Name Error yes 1 0
What's your old, what's your new ip address?
Looks like you didn't change your dns entry, so the result is expected.
PS: Your http setup looks wrong. / answers with a redirect, but /.well-known/acme-challenge/random-filename has a timeout.
Looks like there is an additional instance (proxy?), perhaps that's the reason of a wrong redirect.
PPS:
Ah
Looks like that Traefik proxy doesn't work as expected. But I have no idea how that must be configured.
Thanks for the reply.
The old IP address is 52.67.50.125.
It was associated to the not working domains, including checkupinteligente.com.
It was never associated to prod.* domains, which have been always associated to the new IP address 18.228.24.153.
I have updated the original post to include this information.
There is a certificate:
checkupinteligente.com, checkupinteligente.com.br,
medicinadescomplicada.com, medicinadescomplicada.com.br,
www.checkupinteligente.com, www.checkupinteligente.com.br,
www.medicinadescomplicada.com, www.medicinadescomplicada.com.br
Looks like your old instance is active. And looks that your proxy sends the traffic to that wrong / not longer valid ip address.
Yes, this is the old certificate used in the old VM setup and generated there using certbot.
Yes, the old VM is still running as a precaution if I need to roll back for any reason, but at this moment there’s no domain name associated to it anymore.
My proxy doesn’t know about IP addresses, I only knows about domain names.
Must I revoke the old certbot generated certificate associated to the old IP address?
Please read some basics about revocation.
The Let’s Encrypt validation servers use whatever IP addresses are in your DNS records (with minimal caching).
Can you provide more of your Traefik logs?
Traefik's log since migration:
time="2020-01-17T19:25:15Z" level=error msg="Unable to obtain ACME certificate for domains "checkupinteligente.com,checkupinteligente.com.br,www.checkupinteligente.com,www.checkupinteligente.com.br,prod.checkupinteligente.com,prod.checkupinteligente.com.br": unable to generate a certificate for the domains [checkupinteligente.com checkupinteligente.com.br www.checkupinteligente.com www.checkupinteligente.com.br]: acme: Error -> One or more domains had a problem:\n[checkupinteligente.com] acme: error: 403 :: urn:ietf:params:acme:error:unauthorized :: Invalid response from https://checkupinteligente.com/ [52.67.50.125]: "\n<html class=\"no-js seed-csp4\" lang=\"en\">\n\t\n\t\t<meta charset=\"utf-8\">\n\t\t\n\t\t\n\t\t<meta name=\"vie", url: \n[checkupinteligente.com.br] acme: error: 403 :: urn:ietf:params:acme:error:unauthorized :: Invalid response from https://checkupinteligente.com/ [52.67.50.125]: "\n<html class=\"no-js seed-csp4\" lang=\"en\">\n\t\n\t\t<meta charset=\"utf-8\">\n\t\t\n\t\t\n\t\t<meta name=\"vie", url: \n[www.checkupinteligente.com] acme: error: 403 :: urn:ietf:params:acme:error:unauthorized :: Invalid response from https://checkupinteligente.com/ [52.67.50.125]: "\n<html class=\"no-js seed-csp4\" lang=\"en\">\n\t\n\t\t<meta charset=\"utf-8\">\n\t\t\n\t\t\n\t\t<meta name=\"vie", url: \n[www.checkupinteligente.com.br] acme: error: 403 :: urn:ietf:params:acme:error:unauthorized :: Invalid response from https://checkupinteligente.com/ [52.67.50.125]: "\n<html class=\"no-js seed-csp4\" lang=\"en\">\n\t\n\t\t<meta charset=\"utf-8\">\n\t\t\n\t\t\n\t\t<meta name=\"vie", url: \n" providerName=leresolver.acme routerName=production@docker rule="Host(checkupinteligente.com,checkupinteligente.com.br,www.checkupinteligente.com,www.checkupinteligente.com.br,prod.checkupinteligente.com,prod.checkupinteligente.com.br)"
time="2020-01-18T10:52:07Z" level=error msg="Error getting challenge for token retrying in 657.702586ms" providerName=leresolver.acme
time="2020-01-18T10:52:07Z" level=error msg="Error getting challenge for token retrying in 689.00588ms" providerName=leresolver.acme
time="2020-01-18T10:52:07Z" level=error msg="Error getting challenge for token retrying in 479.221239ms" providerName=leresolver.acme
time="2020-01-18T10:52:07Z" level=error msg="Error getting challenge for token retrying in 550.082798ms" providerName=leresolver.acme
time="2020-01-18T10:52:07Z" level=error msg="Error getting challenge for token retrying in 263.132575ms" providerName=leresolver.acme
time="2020-01-18T10:52:07Z" level=error msg="Error getting challenge for token retrying in 672.916394ms" providerName=leresolver.acme
time="2020-01-18T10:52:08Z" level=error msg="Error getting challenge for token retrying in 374.8466ms" providerName=leresolver.acme
time="2020-01-18T10:52:08Z" level=error msg="Error getting challenge for token retrying in 856.338218ms" providerName=leresolver.acme
time="2020-01-18T10:52:08Z" level=error msg="Error getting challenge for token retrying in 373.733304ms" providerName=leresolver.acme
time="2020-01-18T10:52:08Z" level=error msg="Error getting challenge for token retrying in 505.241883ms" providerName=leresolver.acme
time="2020-01-18T10:52:08Z" level=error msg="Error getting challenge for token retrying in 819.467815ms" providerName=leresolver.acme
time="2020-01-18T10:52:08Z" level=error msg="Error getting challenge for token retrying in 985.795914ms" providerName=leresolver.acme
time="2020-01-18T10:52:08Z" level=error msg="Error getting challenge for token retrying in 895.378603ms" providerName=leresolver.acme
time="2020-01-18T10:52:08Z" level=error msg="Error getting challenge for token retrying in 397.74191ms" providerName=leresolver.acme
time="2020-01-18T10:52:08Z" level=error msg="Error getting challenge for token retrying in 779.407579ms" providerName=leresolver.acme
time="2020-01-18T10:52:08Z" level=error msg="Error getting challenge for token retrying in 1.106756112s" providerName=leresolver.acme
time="2020-01-18T10:52:08Z" level=error msg="Error getting challenge for token retrying in 1.407108439s" providerName=leresolver.acme
time="2020-01-18T10:52:08Z" level=error msg="Error getting challenge for token retrying in 893.257102ms" providerName=leresolver.acme
time="2020-01-18T10:52:09Z" level=error msg="Error getting challenge for token retrying in 1.409806438s" providerName=leresolver.acme
time="2020-01-18T10:52:09Z" level=error msg="Error getting challenge for token retrying in 732.33455ms" providerName=leresolver.acme
time="2020-01-18T10:52:09Z" level=error msg="Error getting challenge for token retrying in 962.738173ms" providerName=leresolver.acme
time="2020-01-18T10:52:09Z" level=error msg="Error getting challenge for token retrying in 1.49842221s" providerName=leresolver.acme
time="2020-01-18T10:52:09Z" level=error msg="Error getting challenge for token retrying in 823.308797ms" providerName=leresolver.acme
time="2020-01-18T10:52:09Z" level=error msg="Error getting challenge for token retrying in 1.268813931s" providerName=leresolver.acme
time="2020-01-18T10:52:09Z" level=error msg="Error getting challenge for token retrying in 1.684790383s" providerName=leresolver.acme
time="2020-01-18T10:52:10Z" level=error msg="Error getting challenge for token retrying in 995.3484ms" providerName=leresolver.acme
time="2020-01-18T10:52:10Z" level=error msg="Error getting challenge for token retrying in 886.264807ms" providerName=leresolver.acme
time="2020-01-18T10:52:10Z" level=error msg="Error getting challenge for token retrying in 1.505614809s" providerName=leresolver.acme
time="2020-01-18T10:52:10Z" level=error msg="Error getting challenge for token retrying in 1.838333958s" providerName=leresolver.acme
time="2020-01-18T10:52:10Z" level=error msg="Error getting challenge for token retrying in 2.412469635s" providerName=leresolver.acme
time="2020-01-18T10:52:10Z" level=error msg="Error getting challenge for token retrying in 1.809146478s" providerName=leresolver.acme
time="2020-01-18T10:52:11Z" level=error msg="Error getting challenge for token retrying in 2.755458874s" providerName=leresolver.acme
time="2020-01-18T10:52:11Z" level=error msg="Error getting challenge for token retrying in 1.538599536s" providerName=leresolver.acme
time="2020-01-18T10:52:11Z" level=error msg="Error getting challenge for token retrying in 2.664344112s" providerName=leresolver.acme
time="2020-01-18T10:52:11Z" level=error msg="Error getting challenge for token retrying in 2.510006221s" providerName=leresolver.acme
time="2020-01-18T10:52:11Z" level=error msg="Error getting challenge for token retrying in 3.690445844s" providerName=leresolver.acme
time="2020-01-18T10:52:12Z" level=error msg="Error getting challenge for token retrying in 3.283559119s" providerName=leresolver.acme
time="2020-01-18T10:52:12Z" level=error msg="Error getting challenge for token retrying in 1.537433441s" providerName=leresolver.acme
time="2020-01-18T10:52:12Z" level=error msg="Error getting challenge for token retrying in 3.247682277s" providerName=leresolver.acme
time="2020-01-18T10:52:12Z" level=error msg="Error getting challenge for token retrying in 2.261041592s" providerName=leresolver.acme
time="2020-01-18T10:52:13Z" level=error msg="Error getting challenge for token retrying in 2.393602572s" providerName=leresolver.acme
time="2020-01-18T10:52:13Z" level=error msg="Error getting challenge for token retrying in 2.619968159s" providerName=leresolver.acme
time="2020-01-18T10:52:14Z" level=error msg="Error getting challenge for token retrying in 4.707463513s" providerName=leresolver.acme
time="2020-01-18T10:52:14Z" level=error msg="Error getting challenge for token retrying in 4.381750976s" providerName=leresolver.acme
time="2020-01-18T10:52:15Z" level=error msg="Error getting challenge for token retrying in 2.271988448s" providerName=leresolver.acme
time="2020-01-18T10:52:15Z" level=error msg="Error getting challenge for token retrying in 3.874256397s" providerName=leresolver.acme
time="2020-01-18T10:52:15Z" level=error msg="Error getting challenge for token retrying in 2.277098567s" providerName=leresolver.acme
time="2020-01-18T10:52:16Z" level=error msg="Error getting challenge for token retrying in 2.474967917s" providerName=leresolver.acme
time="2020-01-18T10:52:16Z" level=error msg="Error getting challenge for token retrying in 3.281583603s" providerName=leresolver.acme
time="2020-01-18T10:52:16Z" level=error msg="Error getting challenge for token retrying in 4.642864798s" providerName=leresolver.acme
time="2020-01-18T10:52:17Z" level=error msg="Error getting challenge for token retrying in 3.756918138s" providerName=leresolver.acme
time="2020-01-18T10:52:17Z" level=error msg="Error getting challenge for token retrying in 3.632493444s" providerName=leresolver.acme
time="2020-01-18T10:52:18Z" level=error msg="Error getting challenge for token retrying in 4.685024905s" providerName=leresolver.acme
time="2020-01-18T10:52:18Z" level=error msg="Error getting challenge for token retrying in 5.917854085s" providerName=leresolver.acme
time="2020-01-18T10:52:18Z" level=error msg="Error getting challenge for token retrying in 6.098834659s" providerName=leresolver.acme
time="2020-01-18T10:52:19Z" level=error msg="Error getting challenge for token retrying in 5.768108607s" providerName=leresolver.acme
time="2020-01-18T10:52:19Z" level=error msg="Error getting challenge for token retrying in 10.116371131s" providerName=leresolver.acme
time="2020-01-18T10:52:21Z" level=error msg="Error getting challenge for token retrying in 9.85038644s" providerName=leresolver.acme
time="2020-01-18T10:52:21Z" level=error msg="Error getting challenge for token retrying in 8.75226943s" providerName=leresolver.acme
time="2020-01-18T10:52:21Z" level=error msg="Error getting challenge for token retrying in 9.860893688s" providerName=leresolver.acme
time="2020-01-18T10:52:23Z" level=error msg="Error getting challenge for token retrying in 10.391397015s" providerName=leresolver.acme
time="2020-01-18T10:52:24Z" level=error msg="Error getting challenge for token retrying in 9.710316001s" providerName=leresolver.acme
time="2020-01-18T10:52:24Z" level=error msg="Error getting challenge for token retrying in 4.381055715s" providerName=leresolver.acme
time="2020-01-18T10:52:25Z" level=error msg="Error getting challenge for token retrying in 4.533601414s" providerName=leresolver.acme
time="2020-01-18T10:52:29Z" level=error msg="Error getting challenge for token retrying in 7.663438612s" providerName=leresolver.acme
time="2020-01-18T10:52:29Z" level=error msg="Error getting challenge for token retrying in 11.137191257s" providerName=leresolver.acme
time="2020-01-18T10:52:29Z" level=error msg="Error getting challenge for token retrying in 16.997784216s" providerName=leresolver.acme
time="2020-01-18T10:52:29Z" level=error msg="Error getting challenge for token retrying in 10.86257752s" providerName=leresolver.acme
time="2020-01-18T10:52:30Z" level=error msg="Error getting challenge for token retrying in 10.819435217s" providerName=leresolver.acme
time="2020-01-18T10:52:31Z" level=error msg="Error getting challenge for token retrying in 9.649280943s" providerName=leresolver.acme
time="2020-01-18T10:52:33Z" level=error msg="Error getting challenge for token retrying in 9.181185924s" providerName=leresolver.acme
time="2020-01-18T10:52:34Z" level=error msg="Error getting challenge for token retrying in 13.519275414s" providerName=leresolver.acme
time="2020-01-18T10:52:36Z" level=error msg="Error getting challenge for token retrying in 17.339316843s" providerName=leresolver.acme
time="2020-01-18T10:52:40Z" level=error msg="Error getting challenge for token retrying in 19.346564164s" providerName=leresolver.acme
time="2020-01-18T10:52:40Z" level=error msg="Error getting challenge for token retrying in 12.853146398s" providerName=leresolver.acme
time="2020-01-18T10:52:40Z" level=error msg="Error getting challenge for token retrying in 15.980294401s" providerName=leresolver.acme
time="2020-01-18T10:52:41Z" level=error msg="Error getting challenge for token retrying in 25.525008512s" providerName=leresolver.acme
time="2020-01-18T10:52:42Z" level=error msg="Error getting challenge for token retrying in 23.07154903s" providerName=leresolver.acme
time="2020-01-18T10:52:46Z" level=error msg="Error getting challenge for token retrying in 10.724279852s" providerName=leresolver.acme
time="2020-01-18T10:52:47Z" level=error msg="Error getting challenge for token retrying in 28.816363521s" providerName=leresolver.acme
time="2020-01-18T10:52:53Z" level=error msg="Error getting challenge for token retrying in 26.282005325s" providerName=leresolver.acme
time="2020-01-18T10:52:54Z" level=error msg="Error getting challenge for token retrying in 17.63612091s" providerName=leresolver.acme
time="2020-01-18T10:52:56Z" level=error msg="Error getting challenge for token retrying in 36.927367156s" providerName=leresolver.acme
time="2020-01-18T10:52:57Z" level=error msg="Error getting challenge for token retrying in 17.07224297s" providerName=leresolver.acme
time="2020-01-18T10:53:00Z" level=error msg="Error getting challenge for token retrying in 15.95864457s" providerName=leresolver.acme
time="2020-01-18T10:53:05Z" level=error msg="Error getting challenge for token retrying in 35.022740835s" providerName=leresolver.acme
time="2020-01-18T10:53:07Z" level=error msg="Error getting challenge for token retrying in 21.646367968s" providerName=leresolver.acme
time="2020-01-18T10:53:11Z" level=error msg="Cannot retrieve the ACME challenge for token 38Q1KkdM6dM5p9YcC2zQCKCuPoJT4yyBST_PDScr2hY: cannot find challenge for token 38Q1KkdM6dM5p9YcC2zQCKCuPoJT4yyBST_PDScr2hY" providerName=leresolver.acme
time="2020-01-18T10:53:14Z" level=error msg="Cannot retrieve the ACME challenge for token 38Q1KkdM6dM5p9YcC2zQCKCuPoJT4yyBST_PDScr2hY: cannot find challenge for token 38Q1KkdM6dM5p9YcC2zQCKCuPoJT4yyBST_PDScr2hY" providerName=leresolver.acme
time="2020-01-18T10:53:16Z" level=error msg="Cannot retrieve the ACME challenge for token TPI-JjDLn9CJjw9oBgRCto8_LiTDGAnYBkxECiHqsT0: cannot find challenge for token TPI-JjDLn9CJjw9oBgRCto8_LiTDGAnYBkxECiHqsT0" providerName=leresolver.acme
time="2020-01-18T10:53:19Z" level=error msg="Cannot retrieve the ACME challenge for token TPI-JjDLn9CJjw9oBgRCto8_LiTDGAnYBkxECiHqsT0: cannot find challenge for token TPI-JjDLn9CJjw9oBgRCto8_LiTDGAnYBkxECiHqsT0" providerName=leresolver.acme
time="2020-01-18T10:53:28Z" level=error msg="Cannot retrieve the ACME challenge for token 38Q1KkdM6dM5p9YcC2zQCKCuPoJT4yyBST_PDScr2hY: cannot find challenge for token 38Q1KkdM6dM5p9YcC2zQCKCuPoJT4yyBST_PDScr2hY" providerName=leresolver.acme
time="2020-01-18T10:53:33Z" level=error msg="Cannot retrieve the ACME challenge for token 38Q1KkdM6dM5p9YcC2zQCKCuPoJT4yyBST_PDScr2hY: cannot find challenge for token 38Q1KkdM6dM5p9YcC2zQCKCuPoJT4yyBST_PDScr2hY" providerName=leresolver.acme
time="2020-01-18T10:53:40Z" level=error msg="Cannot retrieve the ACME challenge for token TPI-JjDLn9CJjw9oBgRCto8_LiTDGAnYBkxECiHqsT0: cannot find challenge for token TPI-JjDLn9CJjw9oBgRCto8_LiTDGAnYBkxECiHqsT0" providerName=leresolver.acme
time="2020-01-18T14:12:48Z" level=error msg="Error getting challenge for token retrying in 674.316461ms" providerName=leresolver.acme
time="2020-01-18T14:12:48Z" level=error msg="Error getting challenge for token retrying in 736.940938ms" providerName=leresolver.acme
time="2020-01-18T14:12:48Z" level=error msg="Error getting challenge for token retrying in 356.280474ms" providerName=leresolver.acme
time="2020-01-18T14:12:48Z" level=error msg="Error getting challenge for token retrying in 260.766891ms" providerName=leresolver.acme
time="2020-01-18T14:12:48Z" level=error msg="Error getting challenge for token retrying in 722.597381ms" providerName=leresolver.acme
time="2020-01-18T14:12:48Z" level=error msg="Error getting challenge for token retrying in 296.485077ms" providerName=leresolver.acme
time="2020-01-18T14:12:48Z" level=error msg="Error getting challenge for token retrying in 859.375031ms" providerName=leresolver.acme
time="2020-01-18T14:12:48Z" level=error msg="Error getting challenge for token retrying in 608.914157ms" providerName=leresolver.acme
time="2020-01-18T14:12:48Z" level=error msg="Error getting challenge for token retrying in 711.348273ms" providerName=leresolver.acme
time="2020-01-18T14:12:48Z" level=error msg="Error getting challenge for token retrying in 740.429436ms" providerName=leresolver.acme
time="2020-01-18T14:12:48Z" level=error msg="Error getting challenge for token retrying in 291.239838ms" providerName=leresolver.acme
time="2020-01-18T14:12:49Z" level=error msg="Error getting challenge for token retrying in 878.87183ms" providerName=leresolver.acme
time="2020-01-18T14:12:49Z" level=error msg="Error getting challenge for token retrying in 675.141217ms" providerName=leresolver.acme
time="2020-01-18T14:12:49Z" level=error msg="Error getting challenge for token retrying in 700.137574ms" providerName=leresolver.acme
time="2020-01-18T14:12:49Z" level=error msg="Error getting challenge for token retrying in 1.087412405s" providerName=leresolver.acme
time="2020-01-18T14:12:49Z" level=error msg="Error getting challenge for token retrying in 921.747676ms" providerName=leresolver.acme
time="2020-01-18T14:12:49Z" level=error msg="Error getting challenge for token retrying in 1.12430868s" providerName=leresolver.acme
time="2020-01-18T14:12:49Z" level=error msg="Error getting challenge for token retrying in 1.012986357s" providerName=leresolver.acme
time="2020-01-18T14:12:49Z" level=error msg="Error getting challenge for token retrying in 584.784754ms" providerName=leresolver.acme
time="2020-01-18T14:12:49Z" level=error msg="Error getting challenge for token retrying in 1.288168724s" providerName=leresolver.acme
time="2020-01-18T14:12:49Z" level=error msg="Error getting challenge for token retrying in 696.516322ms" providerName=leresolver.acme
time="2020-01-18T14:12:49Z" level=error msg="Error getting challenge for token retrying in 944.546345ms" providerName=leresolver.acme
time="2020-01-18T14:12:50Z" level=error msg="Error getting challenge for token retrying in 2.341317658s" providerName=leresolver.acme
time="2020-01-18T14:12:50Z" level=error msg="Error getting challenge for token retrying in 1.242552613s" providerName=leresolver.acme
time="2020-01-18T14:12:50Z" level=error msg="Error getting challenge for token retrying in 1.423134242s" providerName=leresolver.acme
time="2020-01-18T14:12:50Z" level=error msg="Error getting challenge for token retrying in 904.085967ms" providerName=leresolver.acme
time="2020-01-18T14:12:50Z" level=error msg="Error getting challenge for token retrying in 1.381024413s" providerName=leresolver.acme
time="2020-01-18T14:12:50Z" level=error msg="Error getting challenge for token retrying in 1.899849308s" providerName=leresolver.acme
time="2020-01-18T14:12:50Z" level=error msg="Error getting challenge for token retrying in 1.709585167s" providerName=leresolver.acme
time="2020-01-18T14:12:51Z" level=error msg="Error getting challenge for token retrying in 966.006602ms" providerName=leresolver.acme
time="2020-01-18T14:12:51Z" level=error msg="Error getting challenge for token retrying in 3.098829804s" providerName=leresolver.acme
time="2020-01-18T14:12:51Z" level=error msg="Error getting challenge for token retrying in 3.492732268s" providerName=leresolver.acme
time="2020-01-18T14:12:51Z" level=error msg="Error getting challenge for token retrying in 2.493725869s" providerName=leresolver.acme
time="2020-01-18T14:12:51Z" level=error msg="Error getting challenge for token retrying in 2.273906693s" providerName=leresolver.acme
time="2020-01-18T14:12:52Z" level=error msg="Error getting challenge for token retrying in 3.372126031s" providerName=leresolver.acme
time="2020-01-18T14:12:52Z" level=error msg="Error getting challenge for token retrying in 1.892981449s" providerName=leresolver.acme
time="2020-01-18T14:12:52Z" level=error msg="Error getting challenge for token retrying in 3.577666378s" providerName=leresolver.acme
time="2020-01-18T14:12:52Z" level=error msg="Error getting challenge for token retrying in 1.455562938s" providerName=leresolver.acme
time="2020-01-18T14:12:54Z" level=error msg="Error getting challenge for token retrying in 5.069222245s" providerName=leresolver.acme
time="2020-01-18T14:12:54Z" level=error msg="Error getting challenge for token retrying in 2.858620845s" providerName=leresolver.acme
time="2020-01-18T14:12:54Z" level=error msg="Error getting challenge for token retrying in 3.168468341s" providerName=leresolver.acme
time="2020-01-18T14:12:54Z" level=error msg="Error getting challenge for token retrying in 4.298075538s" providerName=leresolver.acme
time="2020-01-18T14:12:54Z" level=error msg="Error getting challenge for token retrying in 2.26648459s" providerName=leresolver.acme
time="2020-01-18T14:12:54Z" level=error msg="Error getting challenge for token retrying in 1.954735168s" providerName=leresolver.acme
time="2020-01-18T14:12:55Z" level=error msg="Error getting challenge for token retrying in 4.115185036s" providerName=leresolver.acme
time="2020-01-18T14:12:56Z" level=error msg="Error getting challenge for token retrying in 2.159496178s" providerName=leresolver.acme
time="2020-01-18T14:12:56Z" level=error msg="Error getting challenge for token retrying in 8.533137565s" providerName=leresolver.acme
time="2020-01-18T14:12:56Z" level=error msg="Error getting challenge for token retrying in 6.544987154s" providerName=leresolver.acme
time="2020-01-18T14:12:57Z" level=error msg="Error getting challenge for token retrying in 5.640127119s" providerName=leresolver.acme
time="2020-01-18T14:12:57Z" level=error msg="Error getting challenge for token retrying in 5.068090621s" providerName=leresolver.acme
time="2020-01-18T14:12:58Z" level=error msg="Error getting challenge for token retrying in 4.738819426s" providerName=leresolver.acme
time="2020-01-18T14:12:58Z" level=error msg="Error getting challenge for token retrying in 6.614497099s" providerName=leresolver.acme
time="2020-01-18T14:12:59Z" level=error msg="Error getting challenge for token retrying in 8.292492475s" providerName=leresolver.acme
time="2020-01-18T14:12:59Z" level=error msg="Error getting challenge for token retrying in 4.616109307s" providerName=leresolver.acme
time="2020-01-18T14:13:02Z" level=error msg="Error getting challenge for token retrying in 3.897818874s" providerName=leresolver.acme
time="2020-01-18T14:13:02Z" level=error msg="Error getting challenge for token retrying in 8.355560742s" providerName=leresolver.acme
time="2020-01-18T14:13:03Z" level=error msg="Error getting challenge for token retrying in 11.389843167s" providerName=leresolver.acme
time="2020-01-18T14:13:03Z" level=error msg="Error getting challenge for token retrying in 6.915947114s" providerName=leresolver.acme
time="2020-01-18T14:13:04Z" level=error msg="Error getting challenge for token retrying in 11.156021702s" providerName=leresolver.acme
time="2020-01-18T14:13:05Z" level=error msg="Error getting challenge for token retrying in 7.836686003s" providerName=leresolver.acme
time="2020-01-18T14:13:05Z" level=error msg="Error getting challenge for token retrying in 10.40986755s" providerName=leresolver.acme
time="2020-01-18T14:13:06Z" level=error msg="Error getting challenge for token retrying in 7.746223937s" providerName=leresolver.acme
time="2020-01-18T14:13:07Z" level=error msg="Error getting challenge for token retrying in 11.924303698s" providerName=leresolver.acme
time="2020-01-18T14:13:10Z" level=error msg="Error getting challenge for token retrying in 18.685732647s" providerName=leresolver.acme
time="2020-01-18T14:13:11Z" level=error msg="Error getting challenge for token retrying in 4.431350838s" providerName=leresolver.acme
time="2020-01-18T14:13:13Z" level=error msg="Error getting challenge for token retrying in 16.552074258s" providerName=leresolver.acme
time="2020-01-18T14:13:14Z" level=error msg="Error getting challenge for token retrying in 11.834828599s" providerName=leresolver.acme
time="2020-01-18T14:13:14Z" level=error msg="Error getting challenge for token retrying in 6.601766327s" providerName=leresolver.acme
time="2020-01-18T14:13:15Z" level=error msg="Error getting challenge for token retrying in 11.952017877s" providerName=leresolver.acme
time="2020-01-18T14:13:15Z" level=error msg="Error getting challenge for token retrying in 18.001439241s" providerName=leresolver.acme
time="2020-01-18T14:13:15Z" level=error msg="Error getting challenge for token retrying in 17.372610672s" providerName=leresolver.acme
time="2020-01-18T14:13:19Z" level=error msg="Error getting challenge for token retrying in 6.957243934s" providerName=leresolver.acme
time="2020-01-18T14:13:21Z" level=error msg="Error getting challenge for token retrying in 22.278513653s" providerName=leresolver.acme
time="2020-01-18T14:13:25Z" level=error msg="Error getting challenge for token retrying in 16.297274947s" providerName=leresolver.acme
time="2020-01-18T14:13:26Z" level=error msg="Error getting challenge for token retrying in 19.288701648s" providerName=leresolver.acme
time="2020-01-18T14:13:27Z" level=error msg="Error getting challenge for token retrying in 25.756040128s" providerName=leresolver.acme
time="2020-01-18T14:13:29Z" level=error msg="Error getting challenge for token retrying in 10.055044565s" providerName=leresolver.acme
time="2020-01-18T14:13:29Z" level=error msg="Error getting challenge for token retrying in 12.001315562s" providerName=leresolver.acme
time="2020-01-18T14:13:33Z" level=error msg="Error getting challenge for token retrying in 14.631073937s" providerName=leresolver.acme
time="2020-01-18T14:13:33Z" level=error msg="Error getting challenge for token retrying in 25.659933369s" providerName=leresolver.acme
time="2020-01-18T14:13:39Z" level=error msg="Error getting challenge for token retrying in 23.492875192s" providerName=leresolver.acme
time="2020-01-18T14:13:41Z" level=error msg="Error getting challenge for token retrying in 14.6377283s" providerName=leresolver.acme
time="2020-01-18T14:13:42Z" level=error msg="Error getting challenge for token retrying in 40.358322837s" providerName=leresolver.acme
time="2020-01-18T14:13:43Z" level=error msg="Error getting challenge for token retrying in 25.092005741s" providerName=leresolver.acme
time="2020-01-18T14:13:45Z" level=error msg="Error getting challenge for token retrying in 17.305261189s" providerName=leresolver.acme
time="2020-01-18T14:13:47Z" level=error msg="Error getting challenge for token retrying in 32.961452423s" providerName=leresolver.acme
time="2020-01-18T14:13:53Z" level=error msg="Cannot retrieve the ACME challenge for token Qbr01mtcyo4jkHVX6B_--FtlHvnOcrR2xNoQbPLrPm0: cannot find challenge for token Qbr01mtcyo4jkHVX6B_--FtlHvnOcrR2xNoQbPLrPm0" providerName=leresolver.acme
time="2020-01-18T14:13:56Z" level=error msg="Cannot retrieve the ACME challenge for token rkpTTO11PsUNm_quABSiK5ay5x8N8Lics9cz6lreK7Y: cannot find challenge for token rkpTTO11PsUNm_quABSiK5ay5x8N8Lics9cz6lreK7Y" providerName=leresolver.acme
time="2020-01-18T14:13:59Z" level=error msg="Cannot retrieve the ACME challenge for token rkpTTO11PsUNm_quABSiK5ay5x8N8Lics9cz6lreK7Y: cannot find challenge for token rkpTTO11PsUNm_quABSiK5ay5x8N8Lics9cz6lreK7Y" providerName=leresolver.acme
time="2020-01-18T14:14:02Z" level=error msg="Cannot retrieve the ACME challenge for token Qbr01mtcyo4jkHVX6B_--FtlHvnOcrR2xNoQbPLrPm0: cannot find challenge for token Qbr01mtcyo4jkHVX6B_--FtlHvnOcrR2xNoQbPLrPm0" providerName=leresolver.acme
time="2020-01-18T14:14:08Z" level=error msg="Cannot retrieve the ACME challenge for token Qbr01mtcyo4jkHVX6B_--FtlHvnOcrR2xNoQbPLrPm0: cannot find challenge for token Qbr01mtcyo4jkHVX6B_--FtlHvnOcrR2xNoQbPLrPm0" providerName=leresolver.acme
time="2020-01-18T14:14:20Z" level=error msg="Cannot retrieve the ACME challenge for token rkpTTO11PsUNm_quABSiK5ay5x8N8Lics9cz6lreK7Y: cannot find challenge for token rkpTTO11PsUNm_quABSiK5ay5x8N8Lics9cz6lreK7Y" providerName=leresolver.acme
time="2020-01-18T14:14:22Z" level=error msg="Cannot retrieve the ACME challenge for token rkpTTO11PsUNm_quABSiK5ay5x8N8Lics9cz6lreK7Y: cannot find challenge for token rkpTTO11PsUNm_quABSiK5ay5x8N8Lics9cz6lreK7Y" providerName=leresolver.acme
More to follow...
Traefik's log from one tentative access to checkupinteligente.com:
time="2020-01-18T17:26:25Z" level=error msg="Error getting challenge for token retrying in 634.944545ms" providerName=leresolver.acme
time="2020-01-18T17:26:26Z" level=error msg="Error getting challenge for token retrying in 968.344002ms" providerName=leresolver.acme
time="2020-01-18T17:26:27Z" level=error msg="Error getting challenge for token retrying in 857.679646ms" providerName=leresolver.acme
time="2020-01-18T17:26:28Z" level=error msg="Error getting challenge for token retrying in 1.429082798s" providerName=leresolver.acme
time="2020-01-18T17:26:29Z" level=error msg="Error getting challenge for token retrying in 1.808967217s" providerName=leresolver.acme
time="2020-01-18T17:26:31Z" level=error msg="Error getting challenge for token retrying in 5.019821469s" providerName=leresolver.acme
time="2020-01-18T17:26:35Z" level=error msg="Error getting challenge for token retrying in 425.56715ms" providerName=leresolver.acme
time="2020-01-18T17:26:36Z" level=error msg="Error getting challenge for token retrying in 824.395689ms" providerName=leresolver.acme
time="2020-01-18T17:26:36Z" level=error msg="Error getting challenge for token retrying in 6.141547393s" providerName=leresolver.acme
time="2020-01-18T17:26:37Z" level=error msg="Error getting challenge for token retrying in 1.027778611s" providerName=leresolver.acme
time="2020-01-18T17:26:38Z" level=error msg="Error getting challenge for token retrying in 1.045997733s" providerName=leresolver.acme
time="2020-01-18T17:26:39Z" level=error msg="Error getting challenge for token retrying in 3.573147196s" providerName=leresolver.acme
time="2020-01-18T17:26:42Z" level=error msg="Error getting challenge for token retrying in 4.730972905s" providerName=leresolver.acme
time="2020-01-18T17:26:42Z" level=error msg="Error getting challenge for token retrying in 2.767608962s" providerName=leresolver.acme
time="2020-01-18T17:26:45Z" level=error msg="Error getting challenge for token retrying in 4.693928274s" providerName=leresolver.acme
time="2020-01-18T17:26:47Z" level=error msg="Error getting challenge for token retrying in 10.902089848s" providerName=leresolver.acme
time="2020-01-18T17:26:50Z" level=error msg="Error getting challenge for token retrying in 7.255447232s" providerName=leresolver.acme
time="2020-01-18T17:26:57Z" level=error msg="Error getting challenge for token retrying in 10.300284715s" providerName=leresolver.acme
time="2020-01-18T17:26:58Z" level=error msg="Error getting challenge for token retrying in 28.231768229s" providerName=leresolver.acme
time="2020-01-18T17:27:07Z" level=error msg="Error getting challenge for token retrying in 22.518708098s" providerName=leresolver.acme
time="2020-01-18T17:27:26Z" level=error msg="Cannot retrieve the ACME challenge for token check-your-website-dot-server-daten-dot-de: cannot find challenge for token check-your-website-dot-server-daten-dot-de" providerName=leresolver.acme
time="2020-01-18T17:27:30Z" level=error msg="Error getting challenge for token retrying in 20.411784075s" providerName=leresolver.acme
time="2020-01-18T17:27:50Z" level=error msg="Cannot retrieve the ACME challenge for token check-your-website-dot-server-daten-dot-de: cannot find challenge for token check-your-website-dot-server-daten-dot-de" providerName=leresolver.acme
time="2020-01-18T17:30:38Z" level=error msg="Error getting challenge for token retrying in 731.569701ms" providerName=leresolver.acme
time="2020-01-18T17:30:38Z" level=error msg="Error getting challenge for token retrying in 601.651781ms" providerName=leresolver.acme
time="2020-01-18T17:30:39Z" level=error msg="Error getting challenge for token retrying in 1.471433716s" providerName=leresolver.acme
time="2020-01-18T17:30:41Z" level=error msg="Error getting challenge for token retrying in 1.070017024s" providerName=leresolver.acme
time="2020-01-18T17:30:42Z" level=error msg="Error getting challenge for token retrying in 3.664643232s" providerName=leresolver.acme
time="2020-01-18T17:30:45Z" level=error msg="Error getting challenge for token retrying in 4.331721118s" providerName=leresolver.acme
time="2020-01-18T17:30:50Z" level=error msg="Error getting challenge for token retrying in 8.276762749s" providerName=leresolver.acme
time="2020-01-18T17:30:58Z" level=error msg="Error getting challenge for token retrying in 11.190214579s" providerName=leresolver.acme
time="2020-01-18T17:31:09Z" level=error msg="Error getting challenge for token retrying in 8.734213956s" providerName=leresolver.acme
time="2020-01-18T17:31:18Z" level=error msg="Error getting challenge for token retrying in 27.732220062s" providerName=leresolver.acme
time="2020-01-18T17:31:46Z" level=error msg="Cannot retrieve the ACME challenge for token check-your-website-dot-server-daten-dot-de: cannot find challenge for token check-your-website-dot-server-daten-dot-de" providerName=leresolver.acme
time="2020-01-18T17:32:17Z" level=error msg="Error getting challenge for token retrying in 665.620518ms" providerName=leresolver.acme
time="2020-01-18T17:32:17Z" level=error msg="Error getting challenge for token retrying in 746.010327ms" providerName=leresolver.acme
time="2020-01-18T17:32:18Z" level=error msg="Error getting challenge for token retrying in 1.52472414s" providerName=leresolver.acme
time="2020-01-18T17:32:20Z" level=error msg="Error getting challenge for token retrying in 2.043130351s" providerName=leresolver.acme
time="2020-01-18T17:32:22Z" level=error msg="Error getting challenge for token retrying in 1.957908602s" providerName=leresolver.acme
time="2020-01-18T17:32:24Z" level=error msg="Error getting challenge for token retrying in 3.44616856s" providerName=leresolver.acme
time="2020-01-18T17:32:27Z" level=error msg="Error getting challenge for token retrying in 8.029031055s" providerName=leresolver.acme
time="2020-01-18T17:32:35Z" level=error msg="Error getting challenge for token retrying in 12.339439619s" providerName=leresolver.acme
time="2020-01-18T17:32:47Z" level=error msg="Error getting challenge for token retrying in 12.796928743s" providerName=leresolver.acme
time="2020-01-18T17:33:00Z" level=error msg="Error getting challenge for token retrying in 15.158952986s" providerName=leresolver.acme
time="2020-01-18T17:33:15Z" level=error msg="Error getting challenge for token retrying in 42.553778808s" providerName=leresolver.acme
time="2020-01-18T17:33:58Z" level=error msg="Cannot retrieve the ACME challenge for token check-your-website-dot-server-daten-dot-de: cannot find challenge for token check-your-website-dot-server-daten-dot-de" providerName=leresolver.acme
The error message with your old IP address is from yesterday. It may have been correct at the time?
I guess that's what it logs when https://check-your-website.server-daten.de/ scans your site and tries to access a /.well-known/acme-challenge/ URL that doesn't exist.
I don't know what that's about...
That looks like a real URL, but who knows what was accessing it or why...
As an additional information, the www.* domain names are CNAME records in DNS, pointing to the main domains, not A records.
Yes, that was the time I have changed the DNS entries to point to the new IP address.
