Letsencrypt.exe and SAN Certs? How Do I?
My domain is:multiple domains
I ran this command:letsencrypt
It produced this output:Not sure
My web server is (include version):IIS7.5
The operating system my web server runs on is (include version):Windows 7 Pro
My hosting provider, if applicable, is:me
I want to install a SAN certificate, as IIS7.5 doesn’t support multiple certs. Every 90 days, my certs get scrambled because the Letsencrypt task runs, thinking it needs all eight domain certs.
So I want to get one SAN cert to cover all eight domains. Right now, only one domain can have a cert.
Can someone walk me through the process? I assume it’s a commandline suffix with Letsencrypt.exe?
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot):unknown.
Hi @Basspig
I don't use this tool. But what's the normal command you use?
To create a SAN certificate, add the other domain names.
IIS.7.5 doesn't support SNI (Server Name Indication), so you must use one https binding with one certificate and 8 domain names.
The main problem is IIS7.5 can’t do SNI.
[but you probably already know that]
The LE.exe command should allow for multiple names in the same request (SAN).
Try using:
--domains "site1.com,www.site1.com,site2.com,www.site2.com,..."
If that fails, try getting help from it:
letsencrypt.exe -help
[if all else fails, try also updating the LE.exe to latest version]
