http-01 challenge for stldintux02.sial.com
http-01 challenge for www.stldintux02.sial.com
Using the webroot path /var/www/certbot for all unmatched domains.
Waiting for verification…
Challenge failed for domain stldintux02.sial.com
Challenge failed for domain www.stldintux02.sial.com
My web server is (include version): I am using Docker Nginx
The operating system my web server runs on is (include version): Linux stldintux02.sial.com 3.10.0-957.1.3.el7.x86_64 #1 SMP Thu Nov 29 14:49:43 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): Docker images (certbot/certbot)
check that a DNS record exists for this domainDomain: www.stldintux02.sial.com
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for www.stldintux02.sial.com - check that a DNS record exists for this
domain
Hello LetsEncrypt,
stldintux02.sial.com this is my internal servers and i want to generate the Certificate for this, could some one please help me to generate the certificate on this.
@JuergenAuer : I have used below command and again getting error
sudo certbot -d stldintux02.sial.com --manual --preferred-challenges dns certonly
Please deploy a DNS TXT record under the name
_acme-challenge.stldintux02.sial.com with the following value:
2mPXbYZpl0i2ucwnPx2SKz6q58BpikTRRI4WlA6pT0s
Before continuing, verify the record is deployed.
Press Enter to Continue
dns-01 challenge for stldintux02.sial.com
Domain: stldintux02.sial.com
Type: dns
Detail: DNS problem: NXDOMAIN looking up TXT for
_acme-challenge.stldintux02.sial.com - check that a DNS record
NOTE: The IP of this machine will be publicly logged as having requested this
certificate. If you’re running certbot in manual mode on a machine that is not
your server, please ensure you’re okay with that.
Are you OK with your IP being logged?
(Y)es/(N)o: y
wPbvV221u41kEKYTvdiMQCqqACq3aSpxbjJTe9zNTY4
Type: dns
@JuergenAuer : Is there any options to change the DNS lookup server name other than default, because its looking for default server and getting the error as failed.
